Put a V8 in it.
Or, you can turbo your RB30E, it's been done plenty of times. Have a search, look on the R31 Skyline Club as well.
If you want twin cam, drop an RB25DET in and do the wiring. Worry about 3L bottom end later.
But since you want a fast reliable car, spend $20k on a 25/30 + all other things required to make it reliable.
For a VL commodore :-) street use but powerful to make pretty good times on the 1/4 mile, so I want a fast realiable car
Cheap, reliable, fast,
You can only have two.
Actually he can have all 3, turbo the RB30E.
If it blows a replacement motor costs a case of beer, and we all know you don't need a DOHC head to make an RB30 perform.
Do the following:
high mount manifold (ask hypergear if BRAE make one and he can get you a discount)
50mm gate from hypergear
hypergear G3 turbo
fmic
tbe
adaptronic ecu (order from hypergear with your turbo and gate) + tune
decent injectors around 1kcc
regrind cam to a decent turbo profile (must be done to make decent power)
Totals about $6,000 if you shop smart.
Add another 2k if you plan to run an RB25 box. Another 1k for a clutch that will hold the power.
It may seem cheaper to slap in a stock RB25 but then you will only need to spend the above 6k on that to make it go fast once you are bored of 150rwkw.
I reckon that answers all your questions in one hit. Thread closed.
OP, before even considering anything why don't you just get that RB25DET running in the first place?
I saw in another post you were asking about "turbo pipe"... get the car running first, then build your knowledge by reading up 10000000000000000000000 other threads about power.
Cheap dirty 30 because as far as the authorities are concerned it has a 30 from the factory .
Anyone who's anyone would be less concerned about a twin cam VL than an RB30 in a Skyline 33 or 34 .
Build it up the std cheap way (rods/NA pistons) and with a Neo turbo head , smaller chambers , the CR should be manageable .
More part throttle torque in a 30 than a 25 and being 20% larger is in theory doing everything the 25 does at 7000 from under 6 . VLs have tall gearing
Lastly you lose the dinosaur distributor / cap / leads with twin cam heads .
A .
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
