Car used to not start randomly after I bought it but would start eventually...., owner said coilpacks were getting hot.. So about a month ago on this hot day, the car would hardley idle, no power sputtering ect after driving for a while. it was absolute balls unless I let it sit for about 5 mins OFF. Then would start but problem would rrepeat every few kms. Coil packs were black as ash burnt out it seemed, so I put new yellow jackets and and new fuel pump and the coilpack loom from my gtr since the rb20 one was falling apart. And then the new fuel pump wass poping off the fuel filter..... Hose was shit around the edges. So after all this car is sweet started every time no stalls nothing drove nice skidded nice ect
Last week or so coming up to lights the revs will drop to about 500 and run stay there but not stall, when a/c is on its normal 850 ish,
Yesterday car died randomly at about 80km but it turned back on once I pulled overy and cranked it.
Drove to home and now won't start,
I have power
I dont have fuel getting pumped
It cranks but no combustion
I put the older pump in which works( connected it to power) but still nothin
I'm about to change o2 sensor
I'm also sus about the fuel pressure regs one has been changed its a nismo one with the bolt on the end.
I'm stuck Im usually fairly good with cars but this has got me f**ked, I've read some earths ect may be cause but all mine seem fine.
Any help would be much appreciated
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
