Hello Community!
You have just found an extremely rare custom-made item.
Very rare custom built extractors.[/size]
Tuned length runners 6-2-1 configuration.[/size]
Twin 3 pipe inlet extractor cones with o2 sensor bung. Merging together to a 3" or 2-1/2" pipe.[/size]
Maximum exhaust extraction design smooth Bends for superior flow. These are perfect for the misbehaving bad-ass P-plater, or that guy who keeps losing his licence.[/size]
Costed $1500 to build will suit rb25de and det all series including neo[/size]
Price is $400.00 ONO (trade parts)[/size]
Will trade for nistune board or ecu to suit neo turbo or na. Or large injectors any other cool bits to suit a RB25 Neo Plus T conversion.[/size]
Contact Josh: 0422898602 [/size]
Item located on Gold Coast.[/size]
  • 1 month later...
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
