Hi all will turbo flutter kill my turbo or is it ok because I love the sound
LOL - the scientific name for turbo flutter is compressor surge. Search it in google - it's not good for your turbo but its not as dramatic as some people make it!
https://www.sau.com.au/forums/topic/435298-turbo-flutter/#findComment-7115618
Surge or stall? I thought its stalling the compressor as the air is traveling back through the compressor wheel. I thiught compressor surge is when the turbo is surging before coming onto boost.
https://www.sau.com.au/forums/topic/435298-turbo-flutter/#findComment-7116201
http://www.turbosmart.com.au/news/flutter-compressor-surge
Compressor surge occurs when the compressor turbine is chopping up excess air which is stored in the compressor housing - occurs when you change gears because the motor rejects the airflow... ;)
Love the sound but hate when people completely over do it and it gets screechy and long...
https://www.sau.com.au/forums/topic/435298-turbo-flutter/#findComment-7116289
Yeah, it sounds Wicked, for about five minutes or untill Mr Police Man says Allo Allo, which ever comes first.
Slows the turbo down so when you change gear you have extra spooling to do before you're on boost again.
Noisey, slow and PoPo.
Recommend. :wacko:
https://www.sau.com.au/forums/topic/435298-turbo-flutter/#findComment-7117059
I don't know about you guys ? You the attitude that well it sounds great so lets do it more ///
For starters the compressor blades would not have equall loading so that induces unbalanced gyroscopic forces 90 degrees in the drirection of rotation, that in laymans terms means at 100,000 rpm the shaft is trying to tear it's self out sideways from the housing. Now that means bearing loads increase and bending moments on the shaft increase. Even if you look at the formula's and simplify it, the force goes up with the square of the speed, look at the speed it's rotating? Golfer know swing faster and hit the ball further, well go figure a hundred thousand rpm or more. You will figure it out in a short enough time ! and we haven't even looked at the unequally loaded blades that are trying to bend off . Yah do it some more !
https://www.sau.com.au/forums/topic/435298-turbo-flutter/#findComment-7118827
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
