hey guys selling my s15 and looking to get into a GTR ...had enough of SR20's . I found a nice white 97 series 3 GTR .....has done 100k's needs the major service done and few little bits and peices etc which is reflected in the price. Just want to know what else is their to look out for and wanting some feedback on the r33 gtr's ???
im looking at making it a super responsive streeter . So looking at some hks gt-ss turbos full exhaust tune etc. Any owners of 33 gtr's with any input or has anyone made this transition from sr20 to rb26 and regretted it???
seems good mate. but when someone doesnt list one bad thing on a n add, prepare for disappointment.
take some one who knows gtrs. and inspect the shit out of it.
yeah i went to look at it ....it needs the 100ks major service and has a blown exhuast gasket which makes a weird sound but reved it revs fine and went for a quick spin drives ok...i opened the oil cap looked inside its a little gunky...would that be a concern????
some bits you can use to determine past life and condition has being removed.
- R34 GTR wheel
- Gear nob, etc
make sure you check out the actual condition of the car and base your decision on that.
anyone buy a GTR in australia locally without a workshop check is stupid.
- R34 GTR wheel
- Gear nob, etc
yeah thanks mate well i put a small deposit on the bassis i said i will need someone to check it over etc and he was happy with that and willing to adjust price accordingly.
just the problem of finding someone who knows their stuff to do this as organising the car to a workshop etc will be a major HF .
Anyone know of anyone in Adelaide who can do the check for cash???
Before you look at it, check if Import Monster still has their white series 3 for sale - It has likely already sold, but on the off chance it has not, check it out
http://www.skylinesaustralia.com/forums/topic/432624-fs-mlb-1997-bcnr33-gt-r-in-white/?hl=%2Bimport+%2Bmonster#entry7056656
i did see that and was keen just the hassle of travelling to view it etc....i will buzz them now cheers
- R34 GTR wheel
- Gear nob, etc
If the 34 wheel is to hide the condition of the original wheel then the original one must be f#$ked!!! That things rooted!
Seems like a pretty good price though. It all looks pretty neat but you'd want to check for rust in the usual places (boot, bonnet hinge area, under front guard area). Not many mods which can be a good thing and a bad thing.
Airfares are cheap, and for the sake of buying from a trusted seller I would say its worth it - Hard to find one that hasn't been screwed with so this is good value at $20k
Yeah the steering wheel came already on car when from japan which i was skeptical but then roaming the web and searching globe-auto japans the GTR specialist i seen a few 33 gtr's for sale with the 34 gtr wheel ....
Surprised no-one has mentioned State Roads. Their inspections are very thorough and they have the equipment to check paint thickness (crash damage), radiator gasses (head gasket) and so on. Pretty well priced too.
contacted aaron to see if still available......if so will get a check done and hopefully can arrange freight if price is right
just googled them seem very good too bad not available in SA typical lol
Yeah I put one in mine and they look a lot better (R33 GTR steering wheels are the same as a S15 steering wheel..... :unsure: ).
I agree with the above though, the car at Import Monster looked amazingly straight and great price.
R33 GTR steering wheel is not the same as an S15 wheel, it's the same as an S14 wheel :)
I would take Aaron's 33 over the one on carsales in a heart beat - nobody replaces a 33 wheel with the most clapped out 34 wheel I've laid eyes on, unless they have a good reason, and fitting a beaten up wheel like that is not done for aesthetics, that's for certain.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
