I am selling a HICAS drag rod which replaces the stock HICAS system.
Its brand new still in box. This is a lot better than installing a lock bar and also provides weight saving benefits once the HICAS is removed.
Below is a link to the part I am selling, its excatly the same as the one listed on this website.
Link: http://www.rhdjapan.com/cusco-drag-rod-super-hicas-nissan.html
I am looking for around $320, I can ship this to anywhere in Australia as well.
I accept PayPal as well.
I was quoted $100 to get this installed by a qualified workshop.
Extract from Website link above:
Description
The CUSCO Drag Rod Super HICAS Nissan is a must for those of you who are serious about tuning your vehicles for high speed circuit, drift, drag and all other spirited driving.
Product Specs
Brand: CUSCO
Product: Drag Rod Super HICAS Nissan
Part Num: 222 474 TC
SPECIFICATIONS:
Features:
Provide precise handling for nissan's equipped with HICAS.
- The Drag Rod replaced HICAS systems, eliminating the softness feel at high speed by providing a direct feel in car control and traction.
Material: Steel.
COMPATIBILITY NOTES:
- Only Vehicles Equipped with HICAS
- R34: Only 2WD Vehicles (Except for BNR34).
https://www.sau.com.au/forums/topic/435308-r34-gtt-cusco-hicas-delete-drag-rod/
It's the whole kit as per the pic in the link I posted. It's all you will need to replace the existing Hicas rods with aftermarket non Hicas rods. Looks quite nice instead of just a lock bar.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
