Just checked my letter box and I got a friendly notice from Dickson saying that there is a report that my number plates don't comply (the platic white and black ones they sell)
I have to present my car for a full inspection.
And it has to be in roadworthy condition so I need to put an urgent help out from anyone.
What I know I need currently.
-stock suspension
-stock rims and tires
-stock exhaust from cat back.
What I'll probably need to do.
-remove boost controller?
-paint rusted looking intercooler pipe.
-replace drivers side seat (has padding missing)
And who knows what else :(
Why does this have to happen before I get my 34
Any help would be appreciated.
https://www.sau.com.au/forums/topic/435335-bend-me-over-dickson/
So I only have one week because its actually 14 days that I have and the letter is dated 18th
What happens if you don't pass? Do they cancel your rego and you have to trailer it home?
Surely they can't just bin it right there and then. I'd guess maybe a 28day period to fix and retest. Just a guess.
Lunchbreak? Communicate with them.
put a seat cover because, they wont be able to see your seat as you will be sitting in the car whole time lol
fix whatever you can but you still going to get failed in the first go. they will find something wrong
Dont stress to much
Also why you looking for a stock suspension, they dont mind having coilovers in the car. (Mine passed with it)
whatever you going to get failed for just fix them as they will only look at what was written down as failed and need to be fixed in your 2nd visit.
I'm sure it's already been said, but if you don't pass you still have time to clear it - there's a further number of weeks between the date the defect need to be cleared and when they cancel your rego.
Honestly I wouldn't stress. You'll have your new car by the time you get this one into roadworthy condition lol
Hey pattey ill come pick up the stock suspension off you on Monday after work as well if that's cool?
At the same time you could check it out for me.
Pretty sure coilovers need to be engineered right?
I'll go pick car seat covers up as well soon.
Nope - the guy at Dicko said I can either put proper coilovers or revert back to stock (I had R33 Coilovers in the rear). They just need to be legal height.
But yeah - you don't get out of your car - they do open your door to read the plates on your driver side door so just whack on a seat cover - you will need 3x child restraints. They DO check to see if it is correctly installed.
I can't offer anything but my recent experience with them :( so here is a hug- :3some:
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
