Like $4000 with it being back to stock parts
I want to take the turbo, coilovers, injectors, boost controller, ECU and Z32 off it
Lets see how this dickson run goes first I guess.
My other option is to get my mum to register it in NSW under her name at a workshop down the coast
Yeah the only thing I'll pretty much be fitting to the 34 will be the turbo.
The rest of the stuff I could still sell off the car and probably make more money than selling it with the car.
Especially since the injectors and things will be no use without the turbo anyways.
Not true. At all.
Hope they don't give you too much pain Dan. If they heard yours no doubt my mate will get a letter for his white s15. :\ so glad i never go up there.
well there you go its not true at all, never mind what i said.
for your coilovers set the eyebrow heights to 370-380mm.
for your boost controller if it is easy to remove and just plumb straight from intake barb to wastegate. otherwise wait to see what they sau.
dont have any gauges on the on the dash or a-pillar if you have a pod filer make sure its secure. as you said just try do the simple obvious stuff and see how you go.
Not true. At all.
ACTUALLY, it's partially true. (from what I gathered from the guy who engineered mine) anything non-OEM that can change the function of the vehicle in any way is supposed to be engineered...whether Dickson give a fark or not is different.
Dash mounted gauges and 33 GT-R wheels needed to be put on mine, not by request of the Dickheads at Dickson, but that's just the way it was supposed to be done.
Exactly!
The laws allow for variance. You can change things within certain boundaries. For example: standard r32 turbos to -7's will not need to be engineered (i know this for a fact). Eiji mentioned a grey area in the act about replacing parts to the closest you can get is allowed. He seemed to know more about it. You can increase power by a certain amount without needing to engineer the car. To simply say any mod requires an engineers cert is completely wrong. ACT is weird in the way it is governed.
Disregard. I dead set honestly have no idea what I was thinking. Derp. What you said is correct and I know it lol, f**k knows what was going on in my head when I wrote that. He only noted them on their because they were there, not because they mattered.
yes that is all true. i didn't mean what i wrote to be taken completely literally. What i meant by factory was factory options eg car came with side mount and is turbo so changing to a front mount or another factory option turbo or similar equivalent is fine. however making a car turbo that never was a factory option would need engineering. This does not at all reflect what i initially wrote. I wrote it quickly and didn't leave much for interpretation so my bad for being misleading, i hope this has all been cleared up now :-)
Anyone know how they go with boot lining and boot struts?
Mine don't hold the boot open and my boot has no carpet either. Below are my current concerns.
-MSD window switch in my glovebox
-intercooler runs under the battery tray
-only one child restraint?
-boot doesn't hold itself up
-no boot lining
-rolled guards with plastic removed
i think you need a spare tire, and only a owners manual. mine passed dickson without boot lining, my boot struts did work and a did have splash guards at the front at that point in time. it didnt have a front mount but the front bumper was modified to one to if they didnt care about that surely the wont care about splash guards.
-no boot lining
Only one will not suffice for child restraints. I had one in the middle - I was told to get 3.
I did - they also asked for an Engineers cert - However, I went to john at Trojan from which he installed it in - I didn't have the time to get the Engineers cert but still went over Dickson. They asked for the Cert - I said I didn't have time getting one, then they asked who installed it and I said John from Trojan to which he ask to see the recipe - the guys checked the back and said it was missing rivet bolts and to sort it out or they'll take my plates - then passed me :)
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
