I'm meeting up with 5hiv on Wednesday arvo to get a cat back exhaust fitted and some R34 rims.
At the same time ill probably try adjust the ride height or tackle that on the weekend.
Checked my child restraints and it looks like I only have one so ill probably grab those off you as well Rob. Not sure how they get fitted though?
If the car fails on too many things is it possible to cancel rego and re-rego in NSW? Or do the defects follow you?
I got f**ked at rego a few months ago... got done with window tint, wheel alignment, no child restraints, to low, to loud, wheel spacers, sub :/, not showing my middle seatbelt clip thing, lower ball joint exc... didn't get done with the turbo timer, pod filter, low brake pads, no engineers report for the child restraints witch Trojan did, they didn't check the Db of the exhaust on second check or the track... f**k they were assholes haha
if you get picked up on that just remove the front tint with a hair dryer...
I removed it all :/ getting the glue off the back window is a shit fight!
I wouldn't worry about it to much.. it sounds like you have all the skyline problems.. if you cant do some of the stuff yourself book it into Trojan, great people down there!
I got my standard shocks and ball joint from them for a good price...
Dunno if it was answered, only skimmed through - regarding the boot lining and struts, you'll be fine. I only had the plastic between the boot and the battery shelf, a sub held in place with tie downs, that's it. Also my struts might as well have not been there lol
Awesome, well I'm going to give it a shot because that doesn't hurt. But still can anyone give info on if I de-rego and then re-rego in NSW would I have any issues?
Only thinking because my parents live down the coast and there are plenty of workshops down there who would allow me to rego it. Could easily chuck it in my parents name for the next 3 months
will need blue slip here so depends on who you take it too will confirm how hard it is.
Just booked it in for the 12th of December :D
So I have some more time to hopefully receive my new car.
Had a chat with the bloke and he said if it fails the inspection then I have a month to get things sorted.
That should allow the time for my R34 to show up MAYBE.
  • Like 1
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
