Here's a few... and relate to fitment in the engine bay, and compatibility with an existing skyline wiring loom.
The DOHC head sits lower than the single cam head.
The DOHC head is setup to use multi-coils, not a distributor like the SOHC head.
Both require a custom intake manifold, but if you go with a 25DET (you can use a greddy plenum) or 26 head you already have a side mount intake manifold.
Don't get too blown away by a power figure. Anything is possible with enough race fuel and boost. This is not a street car engine, and certainly not one built for a skyline.
Everything else you need to know is here:
http://www.skylinesaustralia.com/forums/topic/15420-r33-rb30-conversion/
https://www.sau.com.au/forums/topic/435369-mental-rb30-vid/#findComment-7118919
Awesome engine. You only have to look at the 7 second SOHC VLs to see what the single cammer RB30 can achieve. Having said that the twin cam conversion still has a lot of benefits - for example more low down torque with the VCT running and a better flowing head when unmodified - of course the the 7 sec SOHC cars are no where near standard and as can be seen in the above video the rocker cover has been cut and shut to allow clearance for the much bigger valvetrain residing within. Because of poor maintenance practices and the location of the radiator on the VL the heads on the SOHCs were prone to cracking so if the head has to be changed why not do it with a twin cam head.
https://www.sau.com.au/forums/topic/435369-mental-rb30-vid/#findComment-7118921
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
