could just run this and have both
http://www.ebay.com.au/itm/like/190448345622?lpid=87
i've connected a big red pilot/(shift) light to the factory on/off pressure switch which is handy as u cant miss it when giving the car a beating
Edited by Dan_J
That's the obvious choice ti use a tee piece. but like I said, u need bsp npt is not the right size for the block. Alot of aftermarket stuff is npt cos that's what the yanks use, but the japanes use bsp. It is extremely close but not the same. If you have a search on here you'll find people have had issues with npt fittings.
And just to add, I have both bsp and npt taps, so am completely certain is bsp. The npt tap does start, but after a couple of threads binds up, the bsp tap runs in nicely.
The block (not oil cooler housing) thread for a sensor is BSP, but the RB25 oil pressure sensors that goes into the oil cooler housing is NPT. Here is what I've done with mine:
I've been through all this recently, thinking I would need to make a custom oil manifold to house both sensors. Those are 1/8NPT fittings
Put it this way. you can screw an npt fitting into a bsp. But its not right. If is working for you that's cool, theres nothing to worry about. I have checked the oil cooler hole with my taps and definitely bsp. Nissan wouldnt use 2 different threads, and I'll say it again, nothing jap will have npt threads.
Yeah I thought the same but the two sensors seem to have the same thread. Unless it was very model specific. Didnt really make sense that the block was bsp and the cooler not but the aftermarket sensor screwed into the cooler but not the block. Strange
Perhaps nissan sourced the oil cooler from an aftermarket supplier on certain models. But in the interest of not creating to much confusion here I will agree that it should be bsp
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
