R33 Gtr, Gtst Parts, Fuel Pump, Interior Etc
For Sale:
Bosch 044 fuel pump fitted to R33 cradle ready for direct fitment, near new $100
R33 Rear vision mirror VGC, also same as R32, R34 $20
R33 GTR Clutch master cylinder perfect working condition $40
R33 GTR midnight purple bootlid, (no lip) $40
R33 GTR blow off valves x2 with complete recirculation piping perfect working condition $120
R33 GTR, Will also fit GTST interior lights $40 pair or $20ea
R33 GTR/GTST window plastic trims $20ea
R33 GTR interior fuse box cover $20
R33 GTR front seatbelts VGC $60 pair
R33 GTR C pillars VGC $20 pair
R33 GTR ABS VGC $100
R33 GTR handbrake boot good condition $10
R33 GTR demister dash vents VGC $10 also have complete dash with airbag cover VGC $50
R33 GTR factory turbo alloy elbows $30 pair
Genuine nissan fog lights from R32 m spec model, can make to fit any car $40
Located Gold Coast, will freight at buyers expense
0414596256 John
Edited by slidinr32gtr
  • 2 months later...
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
