FOR SALE
RB25DET SERIES2 ENGINE BRAND NEW
BOTTOM END HAS CP PISTONS, EAGLE RODS, ACL MAIN & ROD BEARINGS ARP HEAD STUD KIT ALL MACHINED TO SUIT. BLOCK HAS BEEN ACID WASHED, DIPPED, CRANK HAS BEEN HEAT TREATED, SCREWED ETC STILL UNASSEMBLED CAN ORGANISE ASSEMBLY.
AS FOR THE HEAD NEW EVERYTHING SOLID CAMS,FERRERA VALVE TRAIN - DOUBLE VALVE SPRINGS, RETAINERS, VALVE LOCKS, FERRERA VAVLES OVERSIZED, SOLID LIFTERS, VAVLE GUIDES HEAD ALL MACHINED TO SUIT AND HEAVILY PORTED & MATCH PORTED.
HAS 6BOOST MANIFOLD, WITH GARRETT TURBO GT42, TIAL WASTEGATE 100MM THROTTLE BODY WITH PLENUM.
ALL THAT IS NEEDED IS OIL & WATER PUMPS, FUEL RAIL & INJECTORS.
THOUSANDS AND THOUSANDS HAVE BEEN SPENT ON THIS.
GENUINE ENQUIRES ONLY $14000ono
https://www.sau.com.au/forums/topic/435444-rb25det-race-engine-unfinished/
Mate 14k isnt bad considering what done. Min 5k in tutbo setup alone, another min 5k in bottem end and as for building a solid lifter heavily ported head can be any where up to 10k. Theres 20k mate so 14k is not that bas considering he is akso neg by the ono after it. Stop trolling.
  • 1 month later...
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
