hi,
My datsun comes with the original l24. My goal at the moment is the rb i have sitting at home to ne in there by mid next year.
With the car being over 30 years old what are the perks in regards to emissions etc.
Has never been registered here. would it make a difference if i register with the l24 and then put in the RB or should i do this frst and say it came like that? im not too sure, and just curious on this.
any help would be great.
Im assuming it would be easier to get complied with the factory engine. just thinking if i can just say it came as is and they will let it pass.
cheers
https://www.sau.com.au/forums/topic/435484-compliance-for-240z/
Pretty sure you have free rein with engine swaps. In QLD you do, as long as you meet power/weight requirements / engineering requirements, you don't have to meet emissions standards for a pre-197(3?) car?
As for compliance, I didn't think there was an awful lot that needed to be done for a car of this age?
I could be wrong, but I was looking into doing a 1J 240z, and the legislation side of things isn't a bother here, its just getting it engineered.
Car will have to comply with the emissions regs in place when the car was built, or when the engine was built, whichever is later. Importing the car is a different kettle of fish - I'm not too sure what the regs on importing modified vehicles currently are (even if it's a personal import). However, if you plan on doing an engine swap, then it will have to be engineered, in which case it needs to comply with the emissions applicable to the engine.
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
