Formula 1 is to make another attempt to ban tyre warmers in 2015.
Previous efforts to introduce a ban have been scuppered because of safety concerns, amid worries from drivers about racing on cold tyres.
But as part of a raft of changes proposed for 2015, the FIA announced on Thursday that all forms of tyre heating devices will be outlawed.
The FIA has also ratified that the minimum weight of cars will increase by 10kg to 701kg in 2015 - which should help alleviate concerns that heavier drivers are put at a disadvantage.
http://www.autosport.com/news/report.php/id/112250
idiots.. didnt pirelli state they need to be within a hot and cold temp range to not explode?
Eric Boullier is set to become McLaren's new Formula 1 team principal after quitting the Lotus team.
Following intense speculation about plans for McLaren following Ron Dennis's review of the organisation, Boullier has resigned from his position as Lotus F1 team principal with immediate effect.
The Frenchman, who has done an impressive job at Lotus despite financial constraints, is now favourite to land the job at McLaren.
Lotus has confirmed that its owner Gerard Lopez will be its new team principal for 2014, and will share responsibility for running the outfit with co-chairman Andrew Ruhan.
Although the loss of Boullier will be a blow to Lotus, the Enstone-based outfit remains hopeful that it has a strong commercial and managerial platform going forwards.
Lopez said: "Lotus F1 Team has never stood still and we head into what promises to be an exciting 2014 season with an innovative new car, new partners and a new management structure at Enstone.
"Great things have been achieved over the past years and we need to continue this momentum.
"We thank Eric for all his hard work over the past four years and we are confident we can continue to fight as one of the top teams in Formula 1 over the seasons ahead."
Lotus is missing next week's first pre-season F1 test, but plans to unveil its new E22 car at the start of the second test in Bahrain.
McLaren is launching its own 2014 challenger at 12pm GMT today (Friday), although it is unclear if it will announce any plans for Boullier.
http://www.autosport.com/news/report.php/id/112254
well f**k me i didn't see that coming..
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
