Formula One 2014
There doesn't seem to be any Pirelli branding on the tyres that the cars are using on track, I wonder if the teams wanted that so that other teams didn't know what tyres they were running and therefore being harder to compare like for like, or if Pirelli didn't want their name to be visible if there was a failure.
Sounds like F1 from the 80s
I like the 80s
Yep!
There's a bloke in Sydney who owns two old Ferrari turbo f1 cars that he brings out to the irace days, the new turbo Ferrari sounds very much the same as his cars.
pretty dull...
First few laps were more installation laps, you can tell he's not flogging it
I'm wondering what the Caterham nose would look like if it was JUST the dildo front end all the way, might look OK. To hard to tell but. Still want to see the Lotus in the flesh, at the moment I like it one minute, hate it the next, strange design
If i didn't already know and had to guess based on the sound, i'd say the new engines were inline 4's rather than V6's
still, i suppose it'll be easier to hear what anyone in the pit lane is saying when they cross to them during thr race...
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
