Formula One 2014
Much better!
But that reminds me I need to order a leave me alone I know what I'm doing t shirt before Melbourne.
They don't sound as terrible now that they're pushing a bit harder, still not F1 though
Just wait till the season starts. None of the drivers will use more than 70% throttle because they'll be too busy saving fuel.
I want to look forward to it, but I can't shake the feeling that Bernie has bent this formula over and is giving it the no-lube cavity search for cash. It's f**ked. Gimmick ideas like DRS to "make a better show" - gay. No refuelling on "safety" grounds yet the lack of fuel load as a strategy variable means everyone just tries to ration it. Tyres that deliberately go off and have a narrow operating window means everyone rations this too. Can't drive too hard - can't afford the fuel bill or to have the tyres go off.
JAS-25T you better upload that 2004 vid before I slit my wrists, this season is depressing and it hasn't even started yet :P
Just over 2 weeks until Melbourne...
Watching them cruise around slowly, conserving fuel, is going to be hard going.
Practice 1,2,3 at turn 1-2 will be the highlight IMO the rest is shaping up like a solar car challenge.
I cruise around slowly conserving fuel for work, and i gotta tell ya... it blows
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
