The stewards' decision in full:
The Stewards, having received a report from the Technical Delegate, heard from the team representatives, have considered the following matter and determine a breach of the regulations has been committed by the competitor named below and impose the penalty referred to.
No/Driver: 3, Daniel Ricciardo
Competitor: Infiniti Red Bull Racing
Time: 20:17
Session: Race
Facts: Car #3 was not in compliance with article 5.1.4 of the FIA Formula 1 technical tegulations.
Offence: Breach of article 3.2 of the FIA Formula 1 sporting regulations and Article 5.1.4 of the FIA Formula 1 technical regulations.
Decision: Car #3 is excluded from the race results.
Reason:
1) The technical delegate reported to the stewards that car #3 exceeded the required fuel mass flow of 100kg/h. (article 5.1.4 of the Formula 1 technical regulations)
2) This parameter is outside of the control of the driver, Daniel Ricciardo.
3) The fuel flow is measured using the fuel flow sensor (Art. 5.10.3 & 5.10.4 of the technical regulations) which is homologated by the FIA and owned and operated by the team.
4) The stewards considered the history of the fitted fuel flow sensor, as described by the team and the technical delegate's representative who administers the programme. Their description of the history of the sensor matches.
a. During practice one a difference in reading between the first three and run four was detected. The same readings as Run 4 were observed throughout practice two.
b. The team used a different sensor on Saturday but did not get readings that were satisfactory to them or the FIA, so they were instructed to change the sensor within parc ferme on Saturday night.
c. They operated the original sensor during the race, which provided the same readings as run four of practice one, and practice two.
5) The stewards heard from the technical representative that when the sensor was installed on Saturday night, he instructed the team to apply an offset to their fuel flow such that the fuel flow would have been legal. He presented an email to the stewards that verified his instruction.
6) The technical representative stated to the stewards that there is variation in the sensors. However, the sensors fall within a known range, and are individually calibrated. They then become the standard which the teams must use for their fuel flow.
7) The team stated that based on the difference observed between the two readings in P1, they considered the fuel flow sensor to be unreliable. Therefore, for the start of the race they chose to use their internal fuel flow model, rather than the values provided by the sensor, with the required offset.
8) Technical directive 01614 (1 March 2014) provides the methodology by which the sensor will be used, and, should the sensor fail, the method by which the alternate model could be used.
a. The technical directive starts by stating: "The homologated fuel flow sensor will be the primary measurement of the fuel flow and will be used to check compliance with articles 5.1.4 and 5.1.5 of the F1 technical regulations..." This is in conformity with articles 5.10.3 and 5.10.4 of the technical regulations.
b. The technical directive goes on to state: "If at any time WE consider that the sensor has an issue which has not been detected by the system WE will communicate this to the team concerned and switch to a back-up system."
(emphasis added.)
c. The back-up system is the calculated fuel flow model with a correction factor decided by the FIA.
9) The FIA technical representative observed thought the telemetry during the race that the fuel flow was too high and contacted the team, giving them the opportunity to follow his previous instruction, and reduce the fuel flow such that it was within the limit, as measured by the homologated sensor - and thus gave the team the opportunity to be within compliance. The team chose not to make this correction.
10) Under Art. 3.2 of the sporting regulations it is the duty of the team to ensure compliance with the technical regulations throughout the event.
Thus the stewards find that:
A) The team chose to run the car using their fuel flow model, without direction from the FIA. This is a violation of the procedure within TD/01614.
B) That although the sensor showed a difference in readings between runs in P1, it remains the homologated and required sensor against which the team is obliged to measure their fuel flow, unless given permission by the FIA to do otherwise.
C) The stewards were satisfied by the explanation of the technical representative that by making an adjustment as instructed, the team could have run within the allowable fuel flow.
D) That regardless of the team's assertion that the sensor was fault, it is not within their discretion to run a different fuel flow measurement method without the permission of the FIA.
The stewards find that car #3 was out of compliance with the technical regulations and is therefore excluded from the results of the race.
Power.
Not economy. The economy part is the fact they only have 100 litres to start and finish the race with.
Fuel flow restricts the maximum power available from the turbo motor. Otherwise with an unrestricted flow, you could run massive power to pass at will, then just trickle around to save fuel.
Power.
Yeah you have to laugh at the mainstream medias attemps to explain what the hell it was he got pinged for. Hopeless. Still brilliant effort by Dan none the less. He just needs to repeat it in a couple weeks and he is on his way to crushing Tool.*
Also good effort by Magnussen. Pretty young looking podium, all up.
*May have gone a bit early with that prediction.
It was a little strange seeing the McLaren not make much ground on the RB down the straight, when all the talk was about how slow the Renault was in a straight line.
Overall it's a sad state of affairs for a sport that revived such a PR boost in this country with Dans result. Not saying it could be over looked for the PR, but it's just sad.
I skimmed over that stewards report, makes me very uneasy about these fuel flow meters for "parity".
Back in the eighties they used to have the same issues with the boost limiters (bovs basically if i remember correctly) they used to limit the turbo motors. FIA stuff was not up to scratch and the teams quickly figured out how to game them anyway.
Lets see Vettel get a good weekend in and see if Dan can ruffle feathers. It does look like being a race for the 3rd step between RBR, Williams and McLaren which will make for interesting racing. But Mercedes are clearly quicker much like Seb was in Singapore last year. Pace to burn.
RBR are probably, in leagalese, screwed; but we'll see
To clarify, it turns out not to be L/h fuel flow (volume) but rather mass flow (kg/h)
Depending on the specific gravity of the control fuel and the ambient temp, 100kg/h would probably be between 110-120L/h (?)
here's an excellent picture for all you Kobi fans out there
rajab knows why you're fans, but you deserve pics regardless
http://cdn.c.photoshelter.com/img-get/I0000ZyJhCjP7Gb4/s/1000/I0000ZyJhCjP7Gb4.jpg
Great picture with a caption below it...
"WHAT DEFECT?"
yeah bag him because his rear brakes didn't work.
fans because a Caterham has never been far enough up the grid to crash into anyone before!
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license is $35.00 via the AASA Website) MA Licenses are no longer accepted by AASA https://aasa.com.au/ A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2. Richard Hicks 3. Warren Clark 4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
