Why is this still unresolved? Almost at two weeks later ffs.
It's not unresolved. It's just that RBR didn't like the resolution.
But RBR have been testing meters under FIA observation in the meantime, and have "acquired a number of new fuel flow sensors and will work with the FIA during the (Malaysian GP) weekend to find one that is accurate to the satisfaction of both sides."
They're less likely to do it again this weekend because they have no real hope of keeping the Mercedes powered cars behind them on these long straights unless Renault has made big gains in their engine POWER spec - oops did I say power? I meant reliability - because those are the only changes allowed now, for improved reliability. yeah right... whereas in Aus it was worth the risk because it is a difficult track to pass on.
Edited by hrd-hr30
Slightly worrying that the sensors need to be tested on the car to find an accurate/acceptable one.
They are all tested then an offset applied (eg its 2% over reading or under reading or whatever) and then used. It is easy to say it should be perfect but nothing in this world ever is.
The sensor manufacturer says "52 per cent of its meters are with a 0.1 per cent accuracy reading, with 92 per cent within 0.25 per cent". As you say the offset is applied to level them out, so all cars can use the same mass fuel flow.
"the teams have accepted that when they are alerted to the possibility the sensor could exceed the 100kg per hour rate at peak flow, irrespective of what their own data says, they have to peg back their rate slightly to ensure there is no breach of the rules." Well, every team except one that decided to ignore it and the FIA when fighting for position with a more powerful car...
(quotes from http://www.autosport.com/news/report.php/id/112973)
Edited by hrd-hr30
Well it does because if it was a bullshit number you can understand why they reacted in the way they did.
EG:
FIA: "We now want you to reduce your fuel flow by 5%"
RB: "It was 0.2% on Friday your numbers are clearly rubbish. Get stuffed."
FIA: "Resistance is useless" etc etc*
* Yes I am likening the FIA to the Vogons.
Edited by djr81
EG:
everyone was in the same boat. Other teams adjusted their fuel flow during the race according to what the FIA were seeing from the sensor. Some even chose to run well below the sensor indicated maximum flow to make sure they didn't exceed it. Only one car refused to play by the same rules and the same calibrated/corrected meter everyone was using. .
Edited by hrd-hr30
Half expect RBR are willing to fall on the sword early and bring the BS out in the open. I hear what you are saying about others obeying...but for all we know RBR may have been the worst example being asked to forfeit 4% power vs lesser amounts for others cars.
It matters little, the fact that many cars were all winding back performance, likely to all differing levels then why even have qualifying or practice sessions. Just have a raffle and fit random flow meters to the cars and watch them jockey for position in a race as the FIA tell them to slow down or allow them to speed up all on different levels ...retarded.
I am no fan of RBR...but good on them for busing balls over this now and hopefully we will avoid the farce of inaccurate instruments hurting a percentage of th efields performance over a race weekend, because....lotter dip of erroneous sensors says so
  • Like 2
Kimi has made a great improvement in the Ferrari. Mercedes having tyre wear worries
Might be an interesting weekend after all
yeah looks like it was more than just the new braking system....
but it sounded like he was having tyre issues on the long run too wasnt he?
hopefully the ferraris can take it to the mercs!!!
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
