  On 29/03/2014 at 10:47 AM, hrd-hr30 said:
Once again, that's why the sensors are individually calibrated against a standard bench meter and a correction offset applied, so all teams get the same mass flow and this situation does not exist.
Doesnt really matter how well the sensors are calibrated if they drift from that calibration. Sounds very much like that is the problem RedBull are having.
damm telecast. set record to go an extra 30min and still missed end of Q3. should know by now to extend by heaps, will know for race tonight. Malaysia should have race at about 10am instead of late arvo
Australian Grand Prix Corporation chief executive Andrew Westacott has confirmed it has discussed the idea of an IndyCar race with the government in the wake of the furore over quieter F1 engines.
The extreme option of severing ties with F1 and moving to IndyCar was floated by AGP chairman Ron Walker, also the head of the F1 Promoter’s Association, in the British paper The Independent.
Four-times F1 champion Sebastian Vettel also came out in the press decrying the quieter engines.
“It’s s..t,” Vettel slammed. “I was on the pit wall during the race, and it is quieter than in a bar! I think for the fans it is not good.”
Westacott confirmed to Speedcafe.com that the subject of possible options including the American-based IndyCar Series have been raised with the Victorian government.
Contract negotiations with Formula One Management (FOM) have struck several obstacles highlighted by the backlash amid the muted noise levels of the new-spec F1 1.6litre turbo engines.
There have also been concerns over F1 chief Bernie Ecclestone’s offer of a ‘watered down contract’ that compromised the future of V8 Supercars support races and associated entertainment.
It is understood Ecclestone’s motive is driven by flexibility in order to appoint more global partners and not be commercially restrained from local arrangements.
Westacott has confirmed the AGP is in constant discussions with FOM and its legal team in a bid to resolve concerns ahead of renewing another F1 contract for the Albert Park event.
“We’ve been working with F1 for 19 years and we want to have the biggest and best motorsport in the world,” Westacott told Speedcafe.com
“(But) we’ve got a situation here where the chemistry has changed.
“When F1 goes to those European circuits and they are no where near as loud or getting the emotion that the spectators can get from GP2 and GP3, the brand itself is going to be put to the test.
“We are in contract renegotiations and we’ve just got to make sure that we are getting the best product.
“It will probably be shown that the best product remains F1 but IndyCar is also a very, very good product out there in the world and it comes at a fraction of the cost.
“There is a degree of credibility from that point of view. “
“You go to an AC-DC concert and you expect it to be blaring out. You go to F1 and you expect it to be the most exciting hit on your senses and it wasn’t.”
Westacott confirmed the government has been briefed on possible options if F1 is lost to Melbourne.
“Generally yes,” he said over the subject of IndyCar being raised with the government.
“Every person who works in events, whether it be a major events company in Victoria or NSW, what we’ve got to do is compare and look at all the options.
“Adelaide has a race that is totally V8s, the Gold Coast used to have Indy and now it has V8s, Homebush has V8s, we’ve got F1.”
IndyCar races were held at Surfers Paradise from 1991 until 2008 with the annual cost to the Queensland government averaging just over $11million since the early 2000s, which is a fraction of what is spent in Victoria on F1.
Westcott says that FOM is beginning to realise the concerns raised by the AGP are valid.
“I think they are realising that there is a lot of fact to the position we are putting to them,” Westacott said.
“You can’t take one element of the chemistry away. It leaves an empty feeling with people (and) at the moment the indication is it is lacking without a higher level of decibels.
“I think the litmus test is going to be Monza, Spa, Hockenheim, Silverstone and Monaco and even this weekend in Malaysia.
“This is a complex issue and Ron makes very strong points and I’m firmly in line with those because it’s the right level.”
http://m.speedcafe.com/2014/03/29/melbourne-considers-indycar-option-government/
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
