along that line of topic, I went to a presentation by the engineer (Tony Wallis) who designed the Bishop Rotary Valve for F1 Merc engines...but was subsequently written out of the rules, apparently due to renaults influence on the matter.
interesting design if anyone wants to look into it. Beats poppet valve, pneumatic or otherwise hands down.
A links for those interested.
http://home.people.net.au/~mrbdesign/PDF/AutoTechBRV.pdf
rotary valves are nothing new. IIRC there was a rotary valve head made back in the day for holden grey motors. Dunstan or something. And I doubt that was the first. Rotary valves have always looked good in theory, but have alot of problems in practice.
That was a different design.
There was also a French engineering company that designed a rotary valve f1 engine in the 80's (similar design to the engines you're thinking of) but I think they ran out of money?
The dunstan engine.
post-83669-13986650742943_thumb.jpg.
Aussie designed BTW.
Speaking of cylinder head design, I'm very much looking forward to seeing productionized versions of the 'Free Valve' infinitely variable pneumatic poppet valve actuation system Koenigsegg have been working on with their engine partner. Don't think solenoid valve actuation will ever be a reality with pissy low-voltage car electrics, but this other system has promise.
The dunstan engine.
attachicon.gifImageUploadedBySAU Community1398665073.979800.jpg.
No, that's exactly the same design principle, only difference is in the execution. Dunstan head runs the rotating valve shaft longitudinally with a port that opens to orrifices in the head casting, BRV runs individual rotary valve shafts at 90deg to the crank centerline necessitating a complicated gear drive system and completely incorporates the port into them. Same idea, different execution. The rotating disc valve is a different design, but shares the common trait that they really don't work reliably!
the significant difference is you can see actual images of a real life Dunstan rotary valve head, BRV ironically only had drawings of their design in that article about how they finally made one that worked!
Edited by hrd-hr30
its just a more effective way of a team getting exposure then a normal sponsor....
just like this shithouse 'jandal' crap, was funny when he said it, but getting f**king annoying seeing it plastered everywhere...
And it continues....thjis time STR . Form Autosport
on JEV.... "While there's been some bad luck this year, the fact he has made Q3 three times (and would surely have done so in Bahrain but for a sudden change in the fuel-flow meter readings that forced the team to turn down the engine) shows he has emerged from the biggest disappointment of his career a stronger driver."
Would be simple to throw a bit of redundancy at them by getting them to run two meters
I was at the Sydney Retro Speedfest at Eastern Creek last weekend, and among the classic cars they had there were some old F1 cars, very cool seeing them out on track.
Team Haas Lola THL1
Benetton B186
Williams FW07
Flame Out Surtees TS9B
Edited by 180fan
yawn... torro rosso = red bull
I've read the full decision of the appeals court - "As evidence of the reliability of its fuel flow model, the Appellant provided a series of graphs...Several graphs actually showed that parameters had changed from one lap to the other and that one cannot, therefore, conclude that the fuel flow model did not change notably... On top of this, it appears that not all parameters... were shown in the graphs"
That was their "proof" - doctored graphs and refusing to fully disclose the parameters used to esitmate fuel flow in their model!
Let's put it to rest already.
Edited by hrd-hr30
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
