Britney gets pole, but only really through a technicality. And then celebrates as if he didn't screw up others laps. They need to bring in a rule where if you cause a yellow with less than 30 seconds to run, or after the session has ended, then you get a penalty.
No they don't. It wasn't on purpose, that's racing (or qualifying in this instance).
I agree that the celebration was a bit much though.
lol that is one of the stupidest things I've ever heard. Let's penalize people for pushing it to the limit in Q3 while trying to get pole.
Rosberg should have stayed right at the end of that escape road as his session was over anyway with only 30 seconds left in Q3 and not enough time to start another lap. With him at the end of that road the yellows should have been cleared and Hamilton would've been able to complete the lap
Doesn't take much for the douchebag in Hamilton to come out!
Rosberg scored 2 little victories there - one over Hamilton for pole and also over Hamilton mentally - he's no poker player! The last thing you'd do is let the other guy know how pissed off you are like that - or carry on like a child in the press conference broadcast to the world!
I wouldn't be surprised if Hamilton does something stupid tonight, or makes one of his trademark silly mistakes...
I don't see why it's stupid. Had he caused a red flag he would've been penalised. Had he been going slow and blocked people he would've been penalised. Had he gone off and pulled back in front of someone while returning to the track he would've been penalised. But sitting a little way down an escape road and then reversing onto the track, while causing a prolonged yellow flag is ok cause he was "just having a go"? Might as well stop penalising people who take another car out when trying to overtake under brakes, because "they are just pushing hard to get a position".
He didn't go slow and block anyone, he didn't go off and pull back in front of anyone and so on... I said he shouldn't be penalized for pushing hard for pole, and f**king it up.
He should probably have copped something for reversing up the escape with the intention of rejoining as he was well aware there was 30 seconds left, and that he could not get around to start a new lap..
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
