Bernie is tied up in court for having paid off someone...I really hope the verdict is such that he needs to step aside from F1 and the next cab off the rank guides it through either sale by CVC or a different style of F1.
So many teams are struggling. Many circuits struggling to get crowds. We are having a cracking season with sooo much good racing. I personally think with the engines and various states of tune through the race and how they deploy their electric power they can do away with DRS. But even if they keep it the sport has bigger problems...and its not the show.
How the hell FOM keep soo much of the revenue whilst the teams get dick, circuit promoters lose money year after year . The show/racing is fine....it woudl be far better if the mid-field had some more dollars from tv rights etc and the sprot did something about stopping Mercedes, RBR and Ferrari from spending 300-400 million a year. Hell, so much of that goes to DHL etc for shipping at higher rates than the public pay for the same thing. Fancy being contracted to a series where you have to use a sponsor and they charge you more than any other company. Good old FOM murdering the sport...rape and pillage.
The older Bernie gets the worse he is getting....or is it his CVC masters?
  • Like 1
Well if you subscribe to the Nigel Roebuck world view CVC is the antichrist.
But for my ten cents worth Ferrari have been a blight on the sport since about the mid nineties. They have managed to get themselves in such a position as to win more money than other teams doing better than them, being able to reject rule changes (Hoping that has now stopped, not sure if it has) and generally regarding themselves as more important than the sport and everyon else in it.
Maybe CVC & Ferrari could fk off and start their own series.
To my mind they need to fix the money and get some more engine equality between the teams running the same engines. So no B spec motors.
Tell us what you really think, Niki.
Niki Lauda has had a go at McLaren and Ferrari for designing "s**t" cars that cannot rival the Mercedes W05.
Mercedes have dominated this year's Championship, winning nine of ten grands prix including six 1-2 results.
While Mercedes have been racing away with the titles, Ferrari president Luca di Montezemolo has been complaining about the F1 rules and the general state of play.
And although McLaren have not joined in, Lauda has still had a go at them for failing to produce a car to rival the Mercedes even though it is powered by the same engine.
"McLaren have the same engine as us and the car is s**t," he told El Pais.
"Where are they? Nowhere.
"Watch the Ferrari: another f***ing car.
"Next year will be difference because they can change half the engine.
"You cannot penalise Brixworth because others are stupid."
Asked specifically about the situation at Ferrari, Lauda said: "Montezemolo is trying everything and decided to bring in Mattiacci. But nobody believes that things will change overnight.
"He tried to convince Newey to join but could not.
"Alonso is very frustrated because for years he is driving a car that does not work.
"Right now he cannot go to McLaren because he has a contract. If you have a contract with Ferrari you cannot leave unless they allow you."
He always has. When he was on channel 9 (About a hundred years ago kiddies) he would routinely struggle over the names of the pay drivers from about p15 downwards. Big Darryl Eastlake had to bail him out. Which tells you just how lame that was.
haha. big Dazza. the only commentator that could hold a candle to Muzza Walker for getting un-neccesarily excited. lulz
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
