No Caterham, no Marussia for the American GP's. Maybe someone will finally get the hint that teams need actual money to keep going. Sure as hell Bernie doesn't need any more and no one cares for whichever private equity muppets are gouging it all this week. Its not just the minnows, the midfield teams are bleeding money too.
This was in Autosport today:
A letter written to Todt by Caterham, Marussia, Sauber and Force India, a copy of which has been seen by AUTOSPORT, laid bare just how expensive F1 was.
It provided an example of what a midfield team was now spending - excluding driver salaries, building leases, hospitality, marketing and media.
Bigger teams are spending more, in some cases much more, while F1's minnows Caterham and Marussia have been trying to get by on much less.
The breakdown for an average team went as follows:
Hybrid power system $28 million
Gearbox and hydraulics $5 million
Fuel and lubricants $1.5 million
Tyres $1.8 million
Electronics $1.95 million
IT $3 million
Salaries $20 million
Travel and trackside facilities $12 million
Chassis production/manufacturing $20 million
Windtunnel/CFD facilities $18.5 million
Utilities and factory maintenance $2 million
HR and professional services $1.5 million
Freight $5 million
TOTAL $120.25 million
Of course such high expenditure only becomes an issue if income does not cover it, which is where much of the current problem has materialised.
Income from F1's commercial rights is only around $55million - roughly half of the cost of competing - for a midfield team like Sauber or Toro Rosso.
Tyres $1.8 million
IT $3 million
Freight $5 million
Fark..
5 million in freight? DHL are raping teams at higher than normal commercial rates. They give money to FOM and get it all back and some by overcharging the contracted teams.
The wind tunnel cost is a joke too. Just let them go testing with a 3rd driver at race meets and on 4 occassions through the season. Then limit windtunnel testing 8ng to say 100hrs
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
