What a maggot!
Formula 1 supremo Bernie Ecclestone says the easiest way to bring down grand prix ticket prices is for teams to accept less commercial rights income.
Bahahahaha!
That is all.
Too soon. I mean he looks to have some talent but shouldn't they put him in something a bit quicker for a year or two? Like a Sauber?
Pressure must be on Team Cheater Abu Dhabi if Kimi is to lead them next year based on this years results.
You would think Grosjean would still be half a chance at either McLaren or TCAD.
I hope something happens somewhere that gives Romain a shot at McLaren or Fezz. Still stick by my statements that Alonso will see out Fezz and Vettel a chance to sign for McLaren for 2016 season with Romain keeping his seat warm for 2015....which will effectively bne a drive off between Romain and Magnussen to see who will partner Vettel in 2016.
As delusional as Maldanado this bloke.
http://www.planetf1.com/driver/18227/9487921/JEV-I-showed-my-potential
Scrappiest of races with penalities, running off the road left right and centre...yet is claiming it as his arrival drive. Where did he qualify again? :) Hack. Off you go to Nissan LMP1 program and leave Romain to fly the F1 flag
Brabham crowd funding appears to be working.
https://www.indiegogo.com/projects/project-brabham
Wonder if it would actually be interesting?
Brabham-Engineer
Brabham-Engineer will involve the community in the development of the team’s racing technology while providing online training on what it takes to reach the pinnacle of motorsport engineering. Project challenges will cover all aspects of aerodynamics, CFD, suspension geometry and gearboxes, where members can get involved in the development of specific parts or even a future Brabham prototype, with certification of their achievements.
We are also in advanced talks with a market-leading CAD software developer to integrate their technology into our web application. You will be able to see your designs come to life as you contribute towards the development of Brabham Racing.
Brabham-Engineer is more than just an e-learning platform. The race team brings everything alive, putting context to our content and a providing a practical experience that’s unlike anything else in the market.
Edited by djr81
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
