As delusional as Maldanado this bloke.
http://www.planetf1.com/driver/18227/9487921/JEV-I-showed-my-potential
Scrappiest of races with penalities, running off the road left right and centre...yet is claiming it as his arrival drive. Where did he qualify again? :) Hack. Off you go to Nissan LMP1 program and leave Romain to fly the F1 flag
obvious troll is obvious
I'm just going to leave this here:
Last 2 races:
Singapore
12 13 Pastor Maldonado Lotus-Renault 60 +66.9 secs 18
13 8 Romain Grosjean Lotus-Renault 60 +68.0 secs 16
Italy
14 13 Pastor Maldonado Lotus-Renault 52 +1 Lap 16
15 99 Adrian Sutil Sauber-Ferrari 52 +1 Lap 14
16 8 Romain Grosjean Lotus-Renault 52 +1 Lap 17
what's that saying? "you're only as good as your last race", or in this case two lol
Edited by hrd-hr30
hmmm,
a "foreign substance" contaminated the electronic circuits in his steering column...
then a later tweet says
the contaminant was a substance used in normal pre-event servicing of the component.
dodgy. If it was a nomal substance used in normal servicing, why would you call it a foreign substance/contaminant? Funny how this normal substance used in normal pre-event servicing only found it's way into the electronics immediately as the cars rolled out for the race, not at the start of the event.
f**k it, i had to listen to years of Webber conspiracy theorists! :P
hmmm,
What substance would you use to "service" a wiring loom that would potentially contaminate the electronics that the loom plugs in to?
Think hair gel is a more believable explanation.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
