No Caterham, no Marussia for the American GP's. Maybe someone will finally get the hint that teams need actual money to keep going. Sure as hell Bernie doesn't need any more and no one cares for whichever private equity muppets are gouging it all this week. Its not just the minnows, the midfield teams are bleeding money too.
This was in Autosport today:
A letter written to Todt by Caterham, Marussia, Sauber and Force India, a copy of which has been seen by AUTOSPORT, laid bare just how expensive F1 was.
It provided an example of what a midfield team was now spending - excluding driver salaries, building leases, hospitality, marketing and media.
Bigger teams are spending more, in some cases much more, while F1's minnows Caterham and Marussia have been trying to get by on much less.
The breakdown for an average team went as follows:
Hybrid power system $28 million
Gearbox and hydraulics $5 million
Fuel and lubricants $1.5 million
Tyres $1.8 million
Electronics $1.95 million
IT $3 million
Salaries $20 million
Travel and trackside facilities $12 million
Chassis production/manufacturing $20 million
Windtunnel/CFD facilities $18.5 million
Utilities and factory maintenance $2 million
HR and professional services $1.5 million
Freight $5 million
TOTAL $120.25 million
Of course such high expenditure only becomes an issue if income does not cover it, which is where much of the current problem has materialised.
Income from F1's commercial rights is only around $55million - roughly half of the cost of competing - for a midfield team like Sauber or Toro Rosso.
Tyres $1.8 million
IT $3 million
Freight $5 million
Fark..
5 million in freight? DHL are raping teams at higher than normal commercial rates. They give money to FOM and get it all back and some by overcharging the contracted teams.
The wind tunnel cost is a joke too. Just let them go testing with a 3rd driver at race meets and on 4 occassions through the season. Then limit windtunnel testing 8ng to say 100hrs
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
