So his rear brakes worked on the warm up lap...then didnt work all of a sudden. ..
Generally, that is the order of occurrence with failures.
One moment things are fine, the next everything turns to shit.
EDIT: couple of seconds too slow I guess...
Edited by iamhe77
http://www.f1fanatic.co.uk/2014/03/16/kobayashi-responsible-massa-crash-stewards/
The FIA stewards have ruled Kamui Kobayashi was not responsible for causing the first-corner collision with removed him and Felipe Massa from the race.
A fault in Kobayashi’s Caterham was blamed for his loss of control at turn one as the race began.
“Having heard from the driver and the technical representatives of the team, and especially reviewing the technical data, the stewards determine that the incident was caused by a serious technical failure completely outside the control of the driver.
Edited by hrd-hr30
Rear brakes seem to be a Bit haphazard as of 2014. The regenerative power systems haven't given the drivers a lot of confidence in braking.
Was it me or was there a lot of cars putting wheels onto the grass into corners over the weekend?
here's an excellent picture for all you Kobi fans out there
rajab knows why you're fans, but you deserve pics regardless
http://cdn.c.photoshelter.com/img-get/I0000ZyJhCjP7Gb4/s/1000/I0000ZyJhCjP7Gb4.jpg
Jarrod got a cracker of a shot there. His other pics are pretty cule with some lurid slides and off track excursions.
http://www.jrmphotography.com.au/
When can we f**k off all of this environmental pandering bullshit and just go back to racing cars?
If they manufacturers leave it will be a good thing, the whole sport will go back to being reasonably priced like it was in the early 90's
Strong penis on the Caterham everything else has snapped off.
Listening to the technical stuff during the broadcast, the rear braking system does seem like there is going to be some failures throughout the year. Fly by wire braking system mixed with the 2 ERS systems working in conjunction with the physical brakes means that there is a large margin of error possible
Despite only recently extending their deal to host the Australian GP, the race's organisers are now crying breach of contract after F1's sound failed to impress.
For the first time this past weekend, fans listened to the new-look Formula One and its quieter 1.6-litre turbocharged V6 engines.
And although the on-track action was worth watching, that didn't stop some from taking to social media to voice their complaints about the sound.
One person who is not happy is Australian GP chairman Ron Walker while Australian Grand Prix Corporation chief executive Andrew Westacott says it could even be deemed a breach of contract.
"One aspect of it was just a little bit duller than it's ever been before and that's part of the mix and the chemistry that they're going to have to get right," Westacott told Fairfax Radioon Monday.
"Ron spoke to (Ecclestone) after the race and said the fans don't like it in the venue.
"We pay for a product, we've got contracts in place, we are looking at those very, very seriously because we reckon there has probably been some breaches."
http://www.planetf1.com/driver/18227/9218290/Aus-organisers-claim-breach-of-contract
They better be careful or they might lose the Aus GP which would be a real shame :(
Bernie likes playing God with GP events, and with so many other countries keen to get a GP I really don't want to see us lose our GP
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
