Just had the car remapped (drives so much better now) but the 4wd light has come on and we can't work out why. As far as I know the 4wd is controlled by a separate ecu, at least it is in the Skyline, so I was presuming it's still the case in the Stagea? This is on a series 1 rs4 that's had a manual gearbox conversion. Not had a problem with the 4wd system before, any help would be appreciated.
https://www.sau.com.au/forums/topic/435505-4wd-light-on/
No gone for the Link G4 ecu.Don't think anything that was done would have affected the throttle position sensor, how would that affect the 4wd?
Yeah could be coincidence, but the light came on as soon as the new ecu was plugged in.
https://www.sau.com.au/forums/topic/435505-4wd-light-on/#findComment-7121608
I have the same problem. Well sort of anyway.
My 4wd light comes on probably 8/10 times I drive the car. Sometimes straight away, some times not at all... I have the rs4s with a 'mines' ecu.
I am putting a new set of wheels on this Friday and getting a wheel alignment so if that doesn't fix it (doubt it will) then further investigation is needed.
I am keen to see if there is known problems that cause this as well.
https://www.sau.com.au/forums/topic/435505-4wd-light-on/#findComment-7125149
Hey mate,
Was it tuned on a 2wd dyno? Might have clutch pack problem if you did...
Can you jack it up so all 4 wheels are off the ground? If you can, spin the rear wheels. If the front wheels turn as you do, you still have pressure in the ATTESA system. If not, you might be in strife. Best case, the clutches took a beating but are ok and you just need to get some more fluid in the system, check the reservoir in the drivers side rear.
I have the R33, R34 GTR service manual if you can get access to a consult box; it will tell you whats going on...
good luck, pm me if you need anything.
m
https://www.sau.com.au/forums/topic/435505-4wd-light-on/#findComment-7127128
  • 3 weeks later...
Ayvon, if your car is the R33 GTR, it's pin 56
http://www.skyline-owners-club.com/forums/showthread.php?t=22456
Link/ViPec and some other computers "share" the TPS signal from the TPS sensor instead of relying it which inturn lowers the voltage at the various control units, the 34 feels it the most because of the MFD, this is an issue I'm having at the moment and the cure, for me atleast, is a buffer to up the voltages back to correct levels
https://www.sau.com.au/forums/topic/435505-4wd-light-on/#findComment-7150916
stagea rs4s s2 run the 25neo
i have replaced factory ecu now im having intermittent 4wd issues im trying to figure out what pinout / wire was suplying the 4wd ecu with tps signal
at this point i was going to t it off straight from tps
https://www.sau.com.au/forums/topic/435505-4wd-light-on/#findComment-7151464
MFD, Multi Function Display, R34 GTR
where are located ?, I have a guy making me a voltage chaser, basically it takes a high imp input and puts out a low imp out put so it can supply the right signal voltage for more things to use, on mine I'm going to cut it in to the wire leaving the ecu, he made me a PWM switching unit for my fuel pump and it works perfectly
https://www.sau.com.au/forums/topic/435505-4wd-light-on/#findComment-7162092
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
