hey, im new to the forum, car scene and australia. im from the uk and im still trying to suss out the best places to go and where to find what i need.
wheels. im looking at work, yokohama and volks, what should i stay away from. the only thing i cant understand if the offset, how it affects handling.
headlights. someone told me i should get them from japan. i saw some at the car show in adelaide the other day that looked sick and he said to look on here as a few guys ordered them together.
cheers
sorry for mylack of knowledge, hope i havent frustrated too many of you
thanks again
tom
(adelaide)
https://www.sau.com.au/forums/topic/435509-newbie-from-sa-after-some-new-parts/
I purchased these. http://www.spyderauto.com/product_list.php?car_make=Infiniti&car_model=G35&year=2005&submit=Go+!
Fitment is good but bulb alignment was necessary. You can see them fitted on my thumbnail.
I went through Ebay Coz i'm lazy and it was much cheaper than other places.
Edited by SuperDry2013
Was good to meet you (and your car) at the SAU National on the weekend Tom!
The answer to all of your questions is http://jessestreeter.com/ - he is an Aussie living in Japan. He is the guy who got our lights in the SAU group buy, and he can organise you any wheels in the world at a great price. That said, the principal sponsor at the SAU Nats was Aaron from www.importmonster.com, and he always stocks great wheels at ok prices.
As for offset, it is the amount that the wheel sits away from the hub. In terms of performance, lower offset is GOOD for your performance, assuming you have the correct camber so your contact patch remains good. Generally speaking though, if you are going to get better offset wheels, then you will also be buying wider wheels and wider tyres, so your contact patch with the road will be improved anyway over stock.
A good website that explains offset is:
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
Oh, and as I mentioned, DO NOT buy lights from the USA like SuperDry did - they are lhd biased to will blind oncoming traffic - VERY illegal. If you had an accident with them fitted, say goodbye to your insurance cover.
welcome to another sa v35 owner :)
like andrew said, jesse streeter is tops! but you need to know your stuff eg part numbers etc
ps sorry i missed the SAUnats carshow, i was meant to enter but had/have terrible sunburn from the trackday on friday.
Yeah I was hoping to see you and your beast there Szymon .... pretty sure there is a trophy floating around for you from your efforts at the track day too (not sure what Ash did with it in the end).
Speaking of trophies, thanks for NOT coming along to the show'n'shine - it meant I brought home this beautiful trophy instead of you :D
  • Like 1
wasnt yours like the only V-series at the show? haha winner by default.nice. :)
a trophy for me? i was runner-up in modified RWD, maybe its for that?
out of 11 or 12 in that class i think..not too bad after a 7 year absence and first time on track in the Skyline.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
