I've sold the motor and gearbox out of my R33 GTST and now that I've got some more time I'll be wrecking the rest of the car. It's a black series 1.5 with 156,000kms on it. Most parts are still in excellent condition unless stated.
All parts are located in Macleod (Vic). Smaller parts I will post at additional expense.
Below is a list of what's available but feel free to enquire about any things I may have missed.
Prices attached but some parts will be open to reasonable offers.
Part Description Asking $
Pod filter with adaptor Needs new foam 50
Turbo custom intake pipe 100
Intake manifold 50
Engine wiring loom 150
Turbo with internal gate GT-2876R low mount 700
Radiator 60
Engine mounts 75
Fuse box lid 20
Radiator overflow bottle 20
Washer bottle and mototrs 25
Aircon condenser 125
Aircon compressor pump 90
Power steering pump 100
Alternator 90
Clutch hard line 20
Master cylinder 60
Manual pedal set 50
Driveshafts 75
Rear diff Some minor play in it 100
Exhaust
Exhaust pipe Blitz 3in 300
Decat pipe Straight 3in bolt on 45
Wheels
Impul NS-01 light weight racing 17in inc tyres, 70% frt, 40% rr 1200
5 stud hubs Front 140
Rear 140
Spare space saver wheel 50
Suspension
Fronts Stock 75
MSD adjustable 100
Rears Stock 75
MSD adjustable 100
Front castor rods 75
Front lower control arms 100
Front upper control arms 50
Brakes
Callipers Front 100
Rear 100
Discs Front 50
Rear 50
Handbrake drum assembly 150
Master brake cylinder 50
Exterior
Body Shell 300
Front reinforcement bar 120
Rear reinforcement bar 100
Front bar Type M 120
Rear bar Stock 100
Side skirts Stock or type M? 100
Rear pods Veilside 70
Spoiler - Series 1 No stop light and scratched 50
Door LH 150
RH 150
Side mirrors LH 50
RH 50
Bonnet Black - resprayed 200
Boot Black - resprayed 100
Front fender LH 75
RH 75
Front wheel liner Front RH 20
Series 1 headlights Front LH 120
Front RH 120
Series 1 tail lights Rear LH 80
Rear RH 80
Indicators Side - clear pair 60
Interior
Seats Front LH Recaro 200
Front RH Recaro 300
Rear seats 50
Floor mats Stock skyline 75
Floor carpet 50
Instrument panel Standard black good condition 100
Centre console 20
Shifter cover 25
Heater core New 3 years ago 50
Heater controls 50
Headliner 50
Boot trim 50
Gear knob Razor aluminium 10
Gear boot & surround Brand new 30
Handbrake boot Brand new 10
Gages Taco - 4in with shift light 60
A pillar twin mount 40
Boost - HKS with solenoid 60
Steering wheel Just wheel - needs recovering 50
Airbag 100
LH door Trim minus switches 50
Window switch 50
Window motor 100
RH door Trim minus switches 50
Window switch 50
Window motor 100
Pillar trims LH 30
RH 20
https://www.sau.com.au/forums/topic/435513-vic-wrecking-r33-gtst-s15-black/
Ill buy the recaro driver side and the floor mats can you send to sydney?
Ash
The floor mats can be sent through Aus post but I don't think the seat will be able to. If you can find a shipping company that's willing to do parts that size then I'm happy to send it.
FOR ALL: I'll try and get pictures out this afternoon of the requests so far!.
Hey will post Aircon compressor pump? I'm keen to buy it.
Not a problem posting the Aircon compressor pump.
Postage should be around $25 to send it with the weight of it. But firstly, where's it sending to because remote areas sometimes attract higher rates?
Can you pm me pics of the gear knob, gear boot + surrounds and handbrake boot?
Both boots are brand new before breaking up the car (initial plan was to do it up and sell the car whole).
Photo and best price for the turbo intake pipe?
Pic attached and the best price is $80 for it.
The intake pipe is aluminium and still has an attachment for the plum back BOV pipe.
PARTS UPDATE:
Floor mats - SOLD
Doors - SOLD
Front bar - SOLD
Headlights - SOLD
Parcel shelf - SOLD
Frt RH qtr panel - SOLD
Keep the questions coming
Aircon compressor - SOLD
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
