Vic - Wrecking R33 Gtst S1.5 - Black
Yeah I have, but the pricing is a little bit too high, think it was like $750 AUD. It's just a sucky thing to find, I think at this point I'm just going to have to wait for someone who is wrecking one.
By WHITEBEAST · Posted
Found one for $2650 in Sydney to replace this mess 🤘. -
R33 GTST rear bearing works the same way as the GTR one - but it's not the same part. You have to get the correct GTST one. You can see the difference between RWD and AWD bearings on this page https://justjap.com/search?q=r33 rear wheel bearing
I'm not 100% sure for a R33 GTST but could check with a VIN#....however in r32 gtr it is a separate bearing which bolts in at the rear (front is separate press in). *to be clear* the bearing bolts to the hub but you still need to press in the stub axle with the wheel studs to the bearing
By IXMandalorianXI · Posted
Hello all. One of my rear wheel bearings has gotten noisy lately, and given my car is 27 years old and likely has never had them replaced (or at least not recently), it's a good time to replace all four. However, I'm a bit confused. Is the rear a hub assembly, and the front just a wheel bearing? Any clarification would be appreciated. Thank you.
