Vic - Wrecking R33 Gtst S1.5 - Black
G'day,
Am interested in rear hubs with immediate brake cables.
How much with postage to Canberra.
Thanks.
FYI, I think you inbox may be full, will not let me send PM to you.
Hey mate,
Sorry, the hubs and handbrake cables are sold pending pickup. If anything changes I'll let you know.
Thanks for the heads up on the inbox as well! It's now clear for anyone trying to send pm's.
Hey mate still got the centre console/handbrake boot?
Also what are you doing with the shell of the car?
Hey mate,
I've still got the center consol/handbrake boot.
The shell im still looking at selling once ive got a few more things out of it. Open to offers depending whats wanted left it it. At the moment there's fuel and brake likes, instrument panel, carpet, garnish trim etc...
  • 3 weeks later...
Just back from holidays so apologies for the delayed replies.
- Front chassis harness is still available with fuse box.
- Confetti recaro seat is sold BUT other recaro is still available and I'll even take $150 just to move it.
- All brake callipers are SOLD.
How much?
I'm after $150 for the chassis harness with the fuse/relay box included. Picture below to confirm we're talking about the same harness (circled in red)?
It's in great condition except for 2 wires on the dash side that need re-soldering due to the alarm being taken out.
Odd question, which side does your brake master cylinder cable connect to? Need on that connects in the driver side..... Just the connector and maybe 4 inches of its cable
Cable??
There aren't any cables as such on the driver's side of the firewall. There is only an adjustable joining rod from the pedal to the cylinder.
Is that what you're after?
 Share
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
    • Can I suggest a 15W50 oil is too heavy. Its a brand new engine - you should be able to run something like a 10W30. Shove some steel wool into your catch can  - more technically "oil/air separator" - so that the oil vapour has something to condense on.
    • Nice write up solder thank you.  that problem had fallen into another days fun. I wanted to get this cold side in and turned over so it was wired up the same to get a start. no luck I got a couple of cough’s before the battery died unfortunately. we have some wether on the way and I’m back to work, I will order your plugs and re wire them in the near future. 🤙
