G'day,
Am interested in rear hubs with immediate brake cables.
How much with postage to Canberra.
Thanks.
FYI, I think you inbox may be full, will not let me send PM to you.
Hey mate,
Sorry, the hubs and handbrake cables are sold pending pickup. If anything changes I'll let you know.
Thanks for the heads up on the inbox as well! It's now clear for anyone trying to send pm's.
Hey mate still got the centre console/handbrake boot?
Also what are you doing with the shell of the car?
Hey mate,
I've still got the center consol/handbrake boot.
The shell im still looking at selling once ive got a few more things out of it. Open to offers depending whats wanted left it it. At the moment there's fuel and brake likes, instrument panel, carpet, garnish trim etc...
  • 3 weeks later...
Just back from holidays so apologies for the delayed replies.
- Front chassis harness is still available with fuse box.
- Confetti recaro seat is sold BUT other recaro is still available and I'll even take $150 just to move it.
- All brake callipers are SOLD.
How much?
I'm after $150 for the chassis harness with the fuse/relay box included. Picture below to confirm we're talking about the same harness (circled in red)?
It's in great condition except for 2 wires on the dash side that need re-soldering due to the alarm being taken out.
Odd question, which side does your brake master cylinder cable connect to? Need on that connects in the driver side..... Just the connector and maybe 4 inches of its cable
Cable??
There aren't any cables as such on the driver's side of the firewall. There is only an adjustable joining rod from the pedal to the cylinder.
Is that what you're after?
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
