OP, if I was in your shoes, this is what I would do.
Seeing that it's a street car ONLY, leave the engine in, put 6-6.5 litres in the sump and drive it (middle of the hump). I don't believe it's cost effective to pull the engine, sump off, pump, baffles then put it back in. You've just done a half assed job. If you're going that far you may aswell spend the little extra and give it a freshen up (IE Ring's and bearings. While you're there pistons and rods... Very easily get out of hand). We are now talking about a rebuild.
If and when the time comes, then do all the above.
Well the engine is coming out regardless because I'm respraying the whole car a different colour including the engine bay, so I will speak to them about doing the rest of the work as well as it's out, it's going to make sense in the long run I guess.
Yeah I certainly wouldn't pull an engine out just to spray paint the bay especially if the engine doesnt NEED work
To do a good paint job it has to come out or it's all just going flake off I don't plan on painting it again, doing it all properly once.
Paint the car and do the engine bay when the motor lets go cause its going to happen soon enough lol I cant believe Croydon told you to pull the motor, put an oil pump and sump on it and leave the rest..... if your dead set on painting the whole car then get the motor rebuilt and do it all at once.
There is no reason that CRD should damage the engine bay, i dont recall destroying anyones freshly painted engine bays when i pulled motors on GTR's.... there is heaps of room to work with when you have done lots of them ;)
As for the sump and pump, CRD use Performance Metalcraft i am pretty sure so the sump will be an awesome bit of kit and you will end up with a NItto pump. Not entirely sure what they are like for longevity, i guess time will tell.
Ok so new plan, respray car blue as it gun metal grey at the moment, and leave the engine bay the colour it is unless masking everything up will look ok
Perfectly said.
Forget all this $1700 sump, $1500 oil pump business... It's just not required.
Overfill the stock sump by 1ltr, drive around fine. Sumps, extensions etc, you'll never need them at that power level and use.
Perfectly said.
Ok cheers guys really appreciate the advice and money your saving me at the moment lol!
What colour is engine bay now, I have blue Gtr and bay is black from factory .. Just curious
It's also black but it has so many scratches on it just looks horrible, guess I could re black but thought it would look nicer in blue.
Not sure the photo really shows how crap it looks!
And this doesn't show how faded the paint is due to the water being on it!
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
