Hey guys getting in early for power cruise next year as I missed out last year without having a car ready. Purchased this beautiful piece from a well know SAU member a few months ago and now its time to get started. At the moment we just throwing it together to get it running and have some fun so some of the mods are extreme and some not so much but all in good time everything should work together in the future :).
Mod list:
Rebuilt rb26 with forged pistons, acl bearings and head studs with a cometic head gasket
Hks T51r Kai with a spl front wheel which has now been machined ready to go by Mr Turbo in the gold coast
6boost exhaust manifold that I have to modify to fit the turbo
Turbosmart 45mm gate
OS twin plate
Accusump setup with oil cooler and oil filter relocation kit
Usual twn 044 surge tank setup
Old school M800 Motec
HKS 100mm intercooler
1600cc injectors
E85
Just going to throw boost at it see how it goes with pump e85 ;)
  • Like 2
https://www.sau.com.au/forums/topic/435549-mnpiii-r33-gtr-powercruise-project/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
