Rb bits! Mostly rb20det!
Located in Devonport. TASMANIA
Can freight at buyers expense.
R32 rb25de non vct head, direct bolt on to rb30e with no modifications. Pressure/crack tested and machined. Ready to bolt on! $600
Rb20det head, bent valves in 2 cylinders $150
RB20det cams(stock)$40 each
Stock exhaust manifolds $30 each
Turbo oil/water lines $30 set
Blue rb20 t-belt covers $25
Brand New dayco rb20det timing belt $60
Rb20/25 non hicas powersteer pump, polished with gold pulley. In Vgc $150
Rb20det flywheel, need skim. $50
Polished alternator and starter. $70 each
Rb30 rocker cover $10
High pressure power steer line. $30
Rb20det cas, 1 polished. $100 each
Standard rb20det injectors $10each
Rb20det knock sensors $20each
Standard rb20det hydraulic lifters/buckets $50 set
Rb20det exh manifold gaskets x2 new $30each
Rb20/25det turbo/manifold gasket $15 new
Rb20det rocker cover gaskets. Hardly used $20set
Rb20det coil pack loom. Unwired to check condition. Vgc $30
Standard rb20det coilpacks $15each
3inch front pipe $60
Standard rb20det inlet, $20
Rb20det fuel rails $20each
Thermost housings $20each
Heat shields, exh manifold $15 each
Rb30 5 speed. Clunks loud in every gear. $50
Rb20det throttle body, no sensors$20
Heaps of standard rb20 bits and pieces floating around so just ask if your needing something.
Don't be scared to make an offer! Need gone!0409402860
Will swap for stuff of interest
