Hey I am new to the skyline world. So I went to mr minit in sydney to get a spare key cut. After scanning for an imobilser chip the guy said I dont need the chipped key. So I got a key cut fot $10. I havent tried it yet. However does this sound right? Will it start?
Thanks in advance
https://www.sau.com.au/forums/topic/435590-v35-300gt-key-question/
I don't have a 300GT, but I would be surprised if they don't have the same NATS system as other V35s. see if it starts the car. If the engine just cranks, but doesn't start, then you need a chipped key.
My 300GT is a P Collections and it has the factory immobiliser and transponder key. I had Mr Minit cut me a spare and they tried to "detect" the transponder but were unable to offer a replacement. The car won't start with the cut key, just turns over. I presume this is the same NATS security that the 350GT versions have.
I doubt it, probably just a factory upgrade. Nats is built into the ecu/bcm, perhaps it's more the bcm that does it, or just the factory alarm you have.
I haven't heard anyone of this forum discuss their V35 having "factory alarm" without it being a NATS.
I have the usual windows label, the flashing LED labelled "Security" on the steering column, car turns over without starting when using cut key etc.
Chris Rogers wrote in his V35 FAQ on immobilisers, "all of them have a factory one and that it is not compliant with insurance nor OZ stds ADR 82/00. Exception is the M35 Stagea"
Its not a requirement of importers to remove the factory immobiliser in NZ.
there is a factory or dealer 'alarm' option which is in addition to the standard NATS immobiliser. Not sure if it can be fitted to a 300GT if it doesn't already have NATS.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
