Depends on what one you get. I have not dealt with them personally but many people here swear by Hypergear. Where is kasko or Troy when you need them.......
haha!
with a turbo upgrade will injectors need to be done to?
Power?
What about suspension?
And a good diff isnt cheap. You cant use the power if you dont have a good diff.
Fix all the shtty bits first, then youll be broke again.
But your car will be reliable.
And yeah its:
turbo, boost controller, fuel pump, injectors (no rail or fpr needed), exhaust, Pod & cold air box, Nistune ecu. And a tune up.
Not cheap.
Did you fix that timing belt?
Its all for nothing if that belt goes.
Dont worry about shiny bits just yet.
Edited by D.I.Y. Mik
what sort of power increases will you see?
250rwkw is fairly common with the highflows. Though lately I've been seeing a lot of 270+ results, some even reaching 300+ on e85 with stock internals. As Anthony has already stated you will need supporting mods to achieve this :)
I was getting drunk haha
Ello ello
Hypergears new high flow is his best turbo and its only $850 and should net you around 250-260kw
I'm running an SS1PU version and making 250kw but that's on 20psi.
You will need all the supporting mods though which adds up after a while.
-ECU
-AFM
-Fuel pump
-injectors
-metal intake
-boost controller
-boost gauge
-intercooler
-exhaust
And a tune
Sortout your suspension and alignment first. I your struggling to put down 150-170kw no point getting 250kw. i have 210rwkw atm and I can drive flatout without spining the wheels on average tires. I recommend front castor arms rear camber arms and a good alignment i run my alignment close to SKs specs but with slighlty more camber.
sweet thanks guys, nah im starting to think its not the timing belt, thinking its a pully that's out of line or to tight... I really hope its not the timing belt!
It is the timing belt.
Yeah, a timing belt idler or the tensioner.
Stop thinking about it and have a look before it breaks.
I got gates belt on and its to tight makes a noise when idling,
Also i just bought a plazmaman plenum and now i have to relocate the AAC somewhere and get the car tuned
if anyone had done a plazmaman plenum and relocated the AAC a help wound be good
It sounds like a Gates belt wound up too tight.
both guys that have hurd the sound both agree with the timing belt, time to start saving.. so awkered dropping my mate off at formal just before with it fuly detailed and having that sound... it spun into second just before, if that says iits standed power or not..
its a bad feeling going to the formal of your school and not being able to attened :(
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
