Hi all,
I need to clear out a couple more items that I have been stashing away for my next build as they are simply going to waste on my shelf.
Sadly, this means I have to let go my set of Genuine Mines Super Outlet Pro Dump Pipes to suit RB26DETT.
These are about as top shelf as you could get, incredibly well made and have a nice big bellmouth design for maximum flow, with a 70mm main section and enlarged turbo outlet.
They are brand new, un-used and looking for a new home.
New price is ~$1200.00 + Post
I will let these go for $795.00 firm
Pickup available in North Sydney, or alternatively I am happy to post them at the buyers expense.
Cheers.
My N1 came with these on a complete Mine's system > 319.5awKw running on 21psi and just a fuel pump/injectors upgrade. No restriction at all & really well designed.
There's no loss of RB sound but it is a wee bit different.
Hope this helps a buyer to decide!
Seing you have a R33, I assume its the 32/33 model and wont fit 34 as it uses different MAF sensor plug diameter?
crossing my fingers its the R34 version you have, if not good luck with sale!
They suit R32/R33/R34 GTR, and you use an 02 sensor adapter plug where needed, depending on if your car uses the smaller or larger sized 02 sensor.
Now it appears that there's a new Mine's front pipe f/s too.
Both Blitz' dump pipes & Spring&Water's front pipe here in Sydney > What a pair! > What a saving!
Thanks all!
Someone give these puppies a new home before I decide to keep them.
Will entertain serious offers close to the asking price (given its $500 cheaper than buying them new already!!!!)
  • 1 month later...
Is the 02 sensor adapter plug included? Do mines include it with the product?
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
