Last Friday (after a shit ton of rain) I started up my Stagea only to find there is a engine check light just as I was about to take off. I believe the code before was 1122 (Throttle Position Motor - Range/Performance).
I got some electrical contact cleaner from Jaycar and gave the connector a nice spray and plugged in and unplugged a couple of times to work it in there. That seemed to have fixed it as I took it for a nice blat around town and didn't have a drama.
Today I went to take the car to an Auto Electrician because I just don't have the time at the moment to get the headlight's sorted for MVR (Currently low beam is HID), and the problem happened again. But no matter what I do I can't get it going again.
I cleared the ECU fault code and started up the engine - idled as normal - once I put my foot on the accelerator pedal the engine check light came on. I have uploaded a video to youtube of the fault code incase I am not reading it right.
I have also attached a pic of the pop up screen in jap.
Any help would be greatly appreciated.
http://www.youtube.com/watch?v=G50VcSbFnTI&feature=youtu.be
Edited by cabbie_bro
https://www.sau.com.au/forums/topic/435633-m35-engine-light-on/
Have ÿou taken the throttle off, and had a look at it? Don't touch/move the throttle butterfly. It may well be clogged up with shit. It's always the plenum side, not the intake side.
The car does a throttle check every time the car shuts down. If it's not in spec, as in shit is preventing it fully shutting, it could throw a code.
Nah I haven't taken the throttle body off yet; will give that a go and make sure I don't touch the butterfly.
I guess giving it a good ol' spray of carby cleaner wouldn't hurt?
But yeah, once the engine check light comes on when you fully press the pedal the revs only go up by 1 line (prob about 100rpm). So it's not like it can even "limp home".
Yep, but be prepared you'll have to do the throttle relearn after to get a decent idle. Use brake cleaner, it's a little less harsh than throttle body. People say they have a coating you can strip off with carny cleaner, the coating is suppose to prevent build up. I think it's kind of ironic tbh, since your in thereto clean the shit anyway. Coating doesn't work real good... :/
Instructions for the throttle reset on the internet. It's a pedal timing thing. Like the ecu lights.
posting for the 11ty time...
Did you clear the fault code as well, and it came back?
Accelerator Pedal Released Position Learning
DESCRIPTION
Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time harness connectorof accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch ON and wait at least 2 seconds.
3. Turn ignition switch OFF and wait at least 10 seconds.
4. Turn ignition switch ON and wait at least 2 seconds.
5. Turn ignition switch OFF and wait at least 10 seconds.
Throttle Valve Closed Position Learning
DESCRIPTION
Throttle Valve Closed Position Learning is an operation to learn the fully closed position of the throttle valve by monitoring the throttle position sensor output signal. It must be performed each time harness connector of electricthrottle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch ON.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning
DESCRIPTION
Idle Air Volume Learning is an operation to learn the idle air volume that keeps each engine within the specific range. It must be performed under any of the following conditions:
Each time electric throttle control actuator or ECM is replaced.
Idle speed or ignition timing is out of specification.
PREPARATION
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
Battery voltage: More than 12.9V (At idle)
Engine coolant temperature: 70 - 100°C (158 - 212°F)
Park/neutral position (PNP) switch: ON
Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, if the parking brake is applied before the engine is started, theheadlamp will not be illuminated.
Steering wheel: Neutral (Straight-ahead position)
Vehicle speed: Stopped
Transmission: Warmed-up
For A/T models with CONSULT-II, drive vehicle until “ATF TEMP SE 1” in “DATA MONITOR” mode of “A/T” system indicates less than 0.9V.
For A/T models without CONSULT-II and M/T models, drive vehicle for 10 minutes.
OPERATION PROCEDURE
With CONSULT-II
1. Perform EC-42, "Accelerator Pedal Released Position Learning" .
2. Perform EC-42, "Throttle Valve Closed Position Learning" .
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic PREPARATION (previously mentioned) are in good order.
5. Select “IDLE AIR VOL LEARN” in “WORK SUPPORT” mode.
6. Touch “START” and wait 20 seconds.
7. Make sure that “CMPLT” is displayed on CONSULT-II screen. If
“CMPLT” is not displayed, Idle Air Volume Learning will not be
carried out successfully. In this case, find the cause of the incident
by referring to the DIAGNOSIS PROCEDURE below.
8. Rev up the engine two or three times and make sure that idle
speed and ignition timing are within the specifications.
Without CONSULT-II
NOTE:
It is better to count the time accurately with a clock.
It is impossible to switch the diagnostic mode when an accelerator pedal position sensor circuit has a malfunction.
6. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried out successfully. In this case, find the cause of the incident by referring to the DIAGNOSTIC PROCEDURE below.
can take multiple goes to get the idle to learn. Then again, if the throttle is fkd, then it probably won't want to do it. When you get it correct it is quite obvious - revs climb to 2000 - drop to just above stall, and then settle.
Looks like you might be up for a new Throttle body. Scotty will be able to hook you up.
They do go occasionally, and as you mentioned, Nissan want drug money for them. 2K for that is a joke. They are available from China through the back door, and you can buy them locally for $300 odd I think.
Received the spare this morning from Scotty.
Swapped out the old one and performed a calibration as per PN-Mad's post - All seems to be well. I can rev it and no MIL light.
Popping down to the shops to grab a couple of new hose clamps then going to take the stag for a drive see how it goes.
Ok - Done some more driving and testing and I think the issue is an electrical short - which I think killed my last throttlebody.
I did some driving around and I can't explain why it died the time the last post of mine was made (was driving with no A/C - turned it on then 2mins later the engine light came on).
But I found a way that always gets the throttlebody to fault.
After clearing the last fault code:
  • I drove for about 22mins then I turned on the fan
  • drove for another 13mins then turned on the A/C (manual).
  • drove for 9mins then turned on Auto (Climit Control)
  • drove for 7mins then turned on the headlights - Fault came up straight away.
  • Cleared the code and drove for another 5mins, turned on the headlights - fault came up again.
  • cleared fault and drove for another 10mins, turned on headlights - fault came up straight away.
  • clearned fault and drove home (5mins) - everything fine.
I am going to take the car to an auto-electrician tomorrow and see if I can get them to see if there is a short somewhere (while leaving the throttle body disconnect so this one doesn't die on me).
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
