Hello helpful people of SAU,
Does anyone know the correct torque for the lug nuts on the M35? The wheels on it are aftermarket 18”, not sure if that makes any difference?
Sorry for the noob question just about to set out on a long road trip in the stag and after losing a wheel on the last road trip I wanna be sure everything is perfect this time (provided no one tries to steal the wheels this time around haha).
Any help/pre road trip tips would be greatly appreciated,
https://www.sau.com.au/forums/topic/435648-lug-nut-torque-on-the-m35/
I run aluminium nuts on my Riceline, so I give them 90-100 Nm, but I think steel nuts should be good for 100-110 Nm.
sorry this is the stagea section mate not skylines.....oh wait hahaahahhaha im kidding mate!
I have the rays duralumin nuts and theyre the shittest, theyre like cheese. The locking nut tool strips the nut.....not good considering price. TBH its basically for the brand/wank factor and serve no purpose!
My experience with RAYS nuts has been different.
I got my RAYS nuts with the wheels I currently have second hand around April 2008 and the only issue I have had with them is apprentice mechanics cross threading them or using the wrong size socket on the rattle gun. Otherwise, since equipping them they have gone through many track days and wheel changes without issue!
I agree that they are for wank factor though... But the blue nuts on silver/blue wheels looks nice :P
I would consider kics nuts next but at $200 roughly....hell to the no. I spent $50 and bought GKtech ones to replace the rays. I hope rays wheels are better than their nuts.
And alex im not a hardparker as much atm maybe when i get the car presentable. We all know you like a good hard......
...park.
Edited by Howaitonaito
What is wrong with the stock nuts? You going for weight saving? Better off taking a dump in that case. :P
I got them because because the stock nuts do fit down the holes in the wheels i had and the wheels i have now but i coulnt get a socket narrow enough to do them up let alone to undo them.
I bought a set of black anodised, splined steel nuts through Taleb Tyres on the forum for $40; they are a deep nut.
I ran tap down a couple of them, as they felt a bit gritty going on, but since then they've been great.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
