Hello helpful people of SAU,
Does anyone know the correct torque for the lug nuts on the M35? The wheels on it are aftermarket 18”, not sure if that makes any difference?
Sorry for the noob question just about to set out on a long road trip in the stag and after losing a wheel on the last road trip I wanna be sure everything is perfect this time (provided no one tries to steal the wheels this time around haha).
Any help/pre road trip tips would be greatly appreciated,
https://www.sau.com.au/forums/topic/435648-lug-nut-torque-on-the-m35/
I run aluminium nuts on my Riceline, so I give them 90-100 Nm, but I think steel nuts should be good for 100-110 Nm.
sorry this is the stagea section mate not skylines.....oh wait hahaahahhaha im kidding mate!
I have the rays duralumin nuts and theyre the shittest, theyre like cheese. The locking nut tool strips the nut.....not good considering price. TBH its basically for the brand/wank factor and serve no purpose!
My experience with RAYS nuts has been different.
I got my RAYS nuts with the wheels I currently have second hand around April 2008 and the only issue I have had with them is apprentice mechanics cross threading them or using the wrong size socket on the rattle gun. Otherwise, since equipping them they have gone through many track days and wheel changes without issue!
I agree that they are for wank factor though... But the blue nuts on silver/blue wheels looks nice :P
I would consider kics nuts next but at $200 roughly....hell to the no. I spent $50 and bought GKtech ones to replace the rays. I hope rays wheels are better than their nuts.
And alex im not a hardparker as much atm maybe when i get the car presentable. We all know you like a good hard......
...park.
Edited by Howaitonaito
What is wrong with the stock nuts? You going for weight saving? Better off taking a dump in that case. :P
I got them because because the stock nuts do fit down the holes in the wheels i had and the wheels i have now but i coulnt get a socket narrow enough to do them up let alone to undo them.
I bought a set of black anodised, splined steel nuts through Taleb Tyres on the forum for $40; they are a deep nut.
I ran tap down a couple of them, as they felt a bit gritty going on, but since then they've been great.
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
