Hi guys, I'm new to the forum and don't have a car. Depending on finances I'm planning on getting an s15 next month.
My preference would be a jdm spec r but there's some aud spec s' and r's for alright prices. Any advice would be appreciated, noting that I'm planning on modding any with the following.
Exhaust, fmic, power fc, injectors, fuel pump and maybe headers.
What would be my best choice?
Thanks
https://www.sau.com.au/forums/topic/435664-interested-in-an-s15/
Chances are, a clean stock AUDM S15 will be better condition than a JDM one of equivalent mileage (not that imports have very high chance of being wound back). The AUDM ones (the standard ones) are usually owned by people who can afford to service it properly and the km are most likely genuine. Plus you get a 260 km/h speedo ;).
If the car you're looking at is modded then it gets tricky.
I own an ADM Spec S, and it is a great car. Do suspension work before you even look at power mods.
Do not even bother with JDM. The market is flooded by accident damaged examples of those (thanks to dealerships). And don't expect to find one with genuine KM's.
Go for an ADM Spec S, it is lighter than the ADM Spec R (as it doesn't have a sunroof).
You'll have much better chances of finding an ADM one that has a straight chassis and original panels.... though these chances will still be slim. Ive scanned the S15 market for a long time.
Cheers, thanks for the advice. Yeh I was planning on putting in coilovers anyway, what else suspension wise?
My eyes have definately been opened from feedback now. I wasn't aware of how many spuds are out there, I used to have a 180sx red top, first Australian owner and my mechanic said it was one of the cleanest and straightest he'd seen. Was just lucky I guess.
Yeah, very lucky haha. Straight and original early model S13's/180s are near impossible to find nowadays.
Massive improvement in front-end stability and turn-in if you install a Nismo Power Brace II or Cusco Tension Bar. Also, install front/rear strut braces. Rigidity wise this is ideal for the street.
I have HKS Hipermax III Coilovers... with 6kg Front/4kg Rear rates. They are a firm ride when the dampers are set hard. From what I've found, going with a coilover that has higher spring rates would be completely overkill for our roads, unless you like drifting. As for alignment adjustability - I have Ikeya Formula rear camber arms, front tension rods (for castor), and rear toe rods.....they really are excellent quality but there are plenty of cheaper options available.
Go with something like that for a basic suspension/rigidity setup and you'll be set. Then down the track you'd have room to install some swaybars.
if your modding who gives a f**k. just go for the bloody cheapest.
f**k panel gaps. f**k lightness, f**k it all.
buy the cheapest and spend your change on mods.
then sell it and buy a real car!
but serious. so long as it isnt rooted, just buy the cheapest bro. :yes:
A couple of good posts above about adm being generally in a lot better condition than jdm models.
I recently spent about 2 months looking for one and bought an adm model with awesome mods for a reasonable price. Saw too many busted jdm models .. My tip .. Check the chassis rails all the time lol
JDM cars have a few benefits... The JDM Spec R engine has 184kW, compared to the 147kW for the AUS spec, same as the S14 series. Better trim, with cool colours on seats and door trims, A-pillar boost gauge, better stereo, climate control, and a ball bearing turbo (i think anyway)
Personally I'd like the GT spec AUD S15, with leather, etc but good luck finding one
I am a newbie too and looking into an s15 for myself but, in saying that I want to do a lot of research too, hence why I joined a couple of forums to find out the main problems to look out for and what not so any info would be very helpful! excuse the intrusion of this thread sir :P
will follow this post for any updates :)
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
