if it is a R32 box and the fuse is pulled so pump can't prime, it will be rwd just like an R32..
there is also another method outlined in the workshop manual which involves pulling the bleed connection, which is above your right knee when in drivers seat, then when you turn the ignition on press the brake pedal 5 times quickly and awd light will flash and you are in rwd...
either will be fine
or install Full Race ETS pro controller, has a switch, much easier
Sweet. Well the shaft idea works as we all know. But it's pretty hard to heat up the rears prior to a 1/4 in 4wd. I run achillies 123s and find them bloody great but way better with a bit of heat in them. I'm going to try the switch on the pump trick. Sound pretty ligit if it's in the manual.
So kick panel next to drivers feet.
Pump with two wires.
Un plug. Or use switch
Pump break until light flashes and stays flashing.
Rwd.
Turn car off.
Plug back in. Or use switch
Turn on.
4wd. Launch with hot tyres.
pretty much, but the plug you are looking for is tucked up near the bonnet release. I've had 2 R33's and on the 97 series3 it was yellow wires white plug, but on my 95 it is yellow wire brown plug, its just a connector with one wire out either side..
Ok sweet. Mines a 96 so could be either. So I put a missile switch in line on which wire? Thanks mate. Really sound advise. I don't mess with stuff until I'm sure I'm not going to kill my baby. First chance to do a ligit 1/4 this Friday night. I'd say it will get banned first pass though. She's not slow! It really shows it's power from 140+ and LOVES 250+. But... No cage.
Go back thru that link I posted and on the second page there is pic of the connector you are looking for. Should be the brown one. Just replace that with a switch. Have a good read of all 3 pages.
Good luck at the drags. Let us know what u run.
  • 1 month later...
There is no plug with one wire going in each side sadly. I can't for the life of me find it. There is literally no plug. There is however a white plug with two yellow and green wires. Is that it?
Probably. Just pull the plug out to see. The light should come on on the dash. then follow the procedure. If its the right one then just insert a switch in the circuit.
Cheers. Will do. It pisses in 11's but here's hoping for a ten. Big on drive it how it is on the street so sub and seats stay in...
You'd hope so, you only need 450-470rwhp in a full weight 33 to get in the low 11s and 120-124 mp. zone :-)
With 600+... Shouldn't even need to warm tyres, should just do it even with a average launch and tie power will sort the rest out
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
