hey guys, I have a hcr 32 (rb20det manual) and am looking at buying a 2nd hand 2 way nismo diff. I found one but its in a r33 housing, will this fit the r32? or will the centre fit into the R32 housing. The guy assures me it will, but I would just like to be sure. The housing it its in doesn't have cooling fins like the one in my car, it has an outlet for an oil cooler I think. it does have 5 bolt shafts like the hcr32. is there any other way I can be sure? any info will be much appreciated thanks guys
https://www.sau.com.au/forums/topic/435706-nismo-diff-centre/
R33 housing will fit into R32 subframe. There are differences though. You have to use the R32 rear cover (different rear mounts), and the R32 diffs do not use a bush in the front mounts (ie they're solid), the R33s use a bush. And if there is ABS involved, then the diffs migh be different lengths.
The centre will fit into the R32 housing. You need to throw both diffs at someone who knows how to set them up properly, and you will probably be wise to get them to check bearings and throw some nre seals into it as they put it back together too.
