Hi guys,
Had my Aircon regassed and all was fine (thought it was too easy for a Gtr) anyway got home and heard a hissing sound and thought it was coolant boiling in turbos . Fast forward 2 weeks went for a drive and air con clutch won't engage. Went back to carbon to look for leaks which we couldn't find so I changed the compressor o rings . We started to add some gas and I heard the hissing again. Dave said to take it home and add air from compressor to find leak which I did. Anyway after about 45 minutes I found the leak was from rear of compressor where the wire comes out there is a brass screw with a tiny hole in it. I checked in my spare compressor and it's the same. Under the screw there is a spring and a seat, anyone know what this is? Clearly it shouldn't leak normally but it must be there for a reason. Can't find it on google, I'm thinking if pulling the rear plate off the old one to see what it is but my feeling is it's an over pressure valve or and bleed hole if something fails? On vw's with zexel compressors they change some sought of valve as part if conversion to 134a could this be needed on Gtr?
Scott
https://www.sau.com.au/forums/topic/435744-air-con-leak/
Totally off topic, but the Indian dude at the shop (where you initially parked) was me LOL. I was getting the air con regassed on my car (I didn't know Carbon did regassing). The compressor on my car doesn't engage, so have to find the electrical fault.
Maybe replace the compressor again? fatz has a couple lying around...
https://www.sau.com.au/forums/topic/435744-air-con-leak/#findComment-7128155
I was going to say hello but wasn't sure u were the owner . It seems its a over pressure valve , maybe we put too much gas in? I didn't give it a squirt to 7k when it started leaking , how much gas did they put in yours? Did they feed just high pressure or low on the firewall as well?
https://www.sau.com.au/forums/topic/435744-air-con-leak/#findComment-7128205
Yep it's an over pressure/temp discharge port but basically means pressure sensor wasn't working to disengage clutch , but also could be indicator of blockage or Thermo fan not working . I will change receiver drier this time too . This discharge thing should relesse some pressure then close which unfortunately it's not doing . They tell machine what to put in, r32 Gtr is 550gms as a good starting point with r12 problem is 134a has different expansion rates so who knows with that?
https://www.sau.com.au/forums/topic/435744-air-con-leak/#findComment-7130107
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
