Doing a garage clean out to get rid of parts I have left over and parts that came from god knows where. Make an offer all has to go pm or sms/call Luke 0408346915. All parts are located briabane northside can deliver for extra cash.
R33 front seats(few rips and tears need some love)
R33 coil packs
R33 igniter pack
R33 front bar and grill(needs paint and a bit of love)
Brand new washer jets universal
R33 10mm wheel spacers
Drivers door window switch pannel
Exterior piller trim things
R33 ecu
Blitz super sound bov with rb25 adapter
R33 airflow meter
R33 instrument cluster
R33 white dash and shifter surround
R33 black dash
Vr/vs clear/chrome after market tail lights
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
