M35 Ecu Upgrade Options
DaveM35
 Share
Often wondered how hard it would be for a tech minded person to simply copy a nismo or impul chip put it on a blank chip and do it that way much like copying an iso image of a movie or computer program.
No-one will spend the time and money on development of a daughter board, but there is another simple option. Just get the Nismo flash off it's processor and dump it into a stock one. Theoretically the Consult 3 can do it, but I am yet to try.
Yeah fair enough.. was thinking tho if our problem is the oem ecu being kept happy, having something intercept the outgoing signal (to modify) and having a closed loop or oem signal returned would be the case in solving some of our problems (which I assumed a daughter board could be of benefit) literally something running the parameters of what the oem ecu should be seeing. Maps etc. (Almost like an safc or crome for honda? ) mind my ignorance
Edited by Reaperblitz
  • 1 month later...
Bumping this thread as my M35 should be ready for tuning very soon.
Currently stock ECU with Emanage piggy backed making just over 240+kw on pump 98.
The car will soon, hopefully, still have the same mods / tune however the auto will be missing (manual yay!)
I assume error codes will appear due to no auto and i do wonder how drivable the car will be with said error codes if at all. If anything it will be an interesting day.
I'm still unsure what path to take to get the car tuned and running fine with the manual in place...
Thoughts?
I wondered how the blokes using Link units are travelling with their tuning.
Cheers
  • Like 1
Cheers for the info Scotty.
I'll let people know how i go starting the M35 once everything is bolted together. Hopefully the error codes wont prevent me driving it with the current set up.
Then I will have the luxury of more time to investigate a real tuning solution.
Has anyone looked at using an EMTRON? They're powerful and can control a heap of stuff, cams, quad DBW throttles and more. They obviously aren't cheap but are well priced for the performance etc they provide. It won't control the auto box but may be a good solution for the engine?
https://www.emtronaustralia.com.au
Also what makes the NISMO ECU better than the stock? I read before that you can ditch the fuel cut and rev cut, anything else?
No throttle delay/restriction.
Worth it; for that ALONE.
As in you wouldn't need the brake cut mod? Or something I've missed?
Brake cut mod is still useful, but the throttle response is much more aggressive and linear.
What you put in at the pedal; you receive instantly at the TB; not a version of it; some days/weeks later...
Ahhhh yea. Lots of DBW cars suffer similarly, you can normally get a little box that plugs in under the accelerator pedal and must alter the signal to ECU/TB. Helps heaps with that and has multiple settings as to how aggressive/sensitive you want it. I think it has an "economy" setting too that must do the opposite and make it less sensitive/aggressive.
The problem is; the controllers can't actually open the throttle from a standstill any faster than standard, so all you get is a weird, jerky oversensitive throttle when you're cruising, with a shiteload of lag off mark...
Considering the price of the ecu is twice what I bought my last stagea for, and you can't actually buy one due to some exclusivity complex they have, I decided to ignore that particular ecu brand. I needed around the clock factory support which even Haltech couldn't give me, infact I am still waiting for a call back from their support line.
Link gave us what we were looking for, a brand new Fury 6 cylinder specific ecu with direct wideband, cvt cam control and the ability to run our M35 electronic throttle in a cheaper package than the other leading brands. Unfortunately it's out of the budget of most Stagea owners, but for those pushing the boundaries with power it should be the best option available, and other than the MAP/IAT and flex sensors it will plug straight in with the patch loom. Finally a better ecu than the Fcon for standalone control.
  • Like 3
Very impressive result for a first start and an untuned drive. Well done guys! Have you fully disconnected the standard ECU from Ricks car now?
No, the stock ecu must remain in place. Rick and I have set the Fury up to run in parallel with the stock ecu, which is still running the cams and throttle. Seems to work well with no errors at this stage. Still a long way to go before removing the stock ecu will be possible, most likely we would need to ditch the auto before going full standalone.
  • Like 1
I'm quickly losing hope that my M35 will be drivable for the xmas break :(
More effort will be made to try and get it running with the 350z manual in place and just tricking the stock ECU that it's an auto box is in neutral...
I'll be there tomorrow afternoon so i will try and take some pictures as i didn't get a chance last weekend :)
I have a feeling once the chaos of xmas is over i'll be asking Scotty and Rick a tonne of questions :P
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
