Great thread guys,
I'm In Brisbane and have an M35 ARX four with SVI Gas.  The only guy I've found who's willing to have a go at tuning both petrol and Gas is strongly recommending a UniChip.  Has anyone tried one? Any thoughts??
I mentioned that lots of M35 owners use adaptronic as a piggyback that local tuners can use.  He still thought UniChip would do a better job.   After reading about the complexity of the task, am I setting myself up for fail by going down the road of a unichip?
Any thoughts appreciated.
Great thread guys,
Hey mate. Im also in brisbane. Good to see more m35s here.
  • 3 months later...
Hi guys long time not posted here on SAU, so i have to registered as new member, so any update for ecu solution for vq25det? i have one of ultimate under my hand and i understand that is budget upgrade for the ecu but how good does it works? also any plugin wiring available for ultimate and vq25
No plug-in options for the emanage unfortunately. you would need a universal loom and map sensor for the emanage.
Scotty does the Link
Jez does the Adaptronic
And I am working on stock ecu rom tunes.
It really depends what you want from the car.
Thanks for reply, Actually car is bone stock for the moment, i know both ecus and even more represented adaptronic in my region, but looking budget option like on stock ecu or even emenage which i can do easily but still looking for some light mods, also i wanted to check the car on dyno but DD we have only rear wheel drive and does stagea supports to have full torque on rear maybe fuse remove or something like this?
more details for stock ecu rom tunes?
Pull the front drive shaft
40 minutes ago, West said:
I made 210kw@4wheels
Mods are the usual + hiflow and an Impul ECU
U mean big intercooler, exhaust and intake ?
few question, in tiptronic between changing the gears hitting few time rpm is ok? and how much should stock boost ? my is about one bar is that normal ?
You're changing gears too late. Increase your rev limiter or change gears alot earlier.
Yes
Speak to Scotty at Scotty Customs, he's stagea (M35) specialist.
http://scottyscustoms.com.au/
  • 4 weeks later...
  • 4 months later...
On 12/8/2016 at 0:30 AM, LenBo said:
Great thread guys,
Did you get your M35 tuned on LPG?
My old NM35 was tuned on LPG...was running a LPI sytem though. Went pretty good...except for the fact the installers botched the job and put a hole in the floor. Front passenger footwell got soaked everytime it rained...
  • 1 month later...
I took my car to dyno today, car is bone stock no modification at all and showed 187 AWHP is that normal results?
i know this post was maybe asked here for 10K times but still how much is average results with ecu tune, intercooler+exhaust mods?
  • 2 years later...
I figured I'd bring this  into 2020, rather than start a fresh one.
I'm about to buy an aftermarket ECU, and leaning towards the Adaptronic M6000. Mainly due to the modular features. I plan to get it up and running as a piggy back then later down the line buy the large expansion module, and have the ECU control my existing LPG system (currently BRC)
Early on in the thread, there's talk of the Adaptronic (previous gen) having a a few limitations with throttle and cam control. I know there's an DBW module you can buy, so assuming that side of this is sorted. Anyone have any idea about cam control with the M6000.
Also does anyone have a base-map for the M6000, or other Adaptronic ECU for the VQ25DET?
After a lot of thought and research I've opted for and ECU Master Black. I decided faffing with the LPG will be more trouble that its worth.
Plus I discovered a 4 wheel rolling road 4 miles from home, and the dudes an ECU master dealer! I had my eye one their piggy back module for another project anyway, so seems logical to stick to one platform. They have a basemap for turbo'd VQ35DE so should be pretty straight forward to get going :)
Probably wont have it fitted for a month or so, but will report back When I do...
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
